Question about Black & Decker Drills
Is Hammer adjust collar attached to chuck?
On an old B&D HAMMERGUN 5078. I am trying to remove the chuck, but it is stuck on really good. Does the hammer adjust collar come off when removing the chuck? Thanks in advance. Bill
  • 2,176 Answers
I looked at a old schematic for the 5078 and it appears that it might come off after chuck removed. The chuck is threaded and if you have the 2 speed model, shift it to low and put a bent handle allen wrench into the jaws and chuck on workbench or block of wood with long portion at approx 30 degree angle and strike the handle, you will be hitting it counter clockwise to remove.
Posted on Jul 25, 2009
How do I add the auxiliary handle to my DeWalt 510 Hammer drill? The 511 manual shows a hinged collar, not found on the handle I have or on any I've seen for sale. That sort would make it easy and sma
Unscrew the handle from the collar and see if it will open wide enough to slide over the chuck and onto the drill neck.
If not, you may have to remove the chuck. Open the chuck jaws completely and look down inside you will see the head of the screw which is holding the chuck onto the drill.
Dec 09, 2014 | Dewalt Drills
Why does my chuck keep loosening
First check whether you have the correct transmission setting for the bit you are using. This may affect the range over which the chuck operates and how it locks onto the bit. A conventional small-diameter drill bit may not work with a hammer drill setting. If the setting is correct, then either your hands aren't as strong as they used to be and you're not getting the chuck tight, or the chuck is worn and no longer has enough friction to hold.
Try this diagnostic: when you put a bit in, use a fine-tip felt marker to draw a line from the chuck collar (the part you turn to tighten or loosen) to the chuck baseplate. If the bit comes loose, check to see if the collar is still lined up at the same place relative to the baseplate. If it is, the chuck pieces are slipping inside; perhaps the transmission setting is incorrect for the bit chosen. If the collar has worked loose (the marks didn't stay lined up), the threading on the collar or the parts it engages could be worn.
May 23, 2014 | Dewalt 18v Battery Hammer Drill Dcd950...
Drillbit stuck
Can not see what model you have. Is it a keyless chuck or an SDS chuck? With a keyless chuck hold the machine in a vice by the drill bit. now tap the chuck with a hammer or pin punch & hammer. DONOT hit the chuck on the jaws gut on the rim around them. I have had success using this method. If it is an SDS type chuck pull the chuck cap up as far as possible along the bit them if there are any ring springs you will have to try remove them then slide the sleeve up the bit, now you should be able to remove any steel balls. If the bit does not come out now hold bit in vice as before and tap on tool holder.
Mar 02, 2014 | Bosch Drills
How do I use the adjustment ring on my ? back out the screws?
You're in trouble. You took the screw out and now the pin is past it's stop. You now have to remove the chuck and then pull the collar of and rotate it so the arrow on it points toward one of the numbers on the tool. Then put the two screws back in put the chuck back on and you'll have full range of adjustment in the collar. The problem is now that you overrotated the collar the clutch is at it's weakest setting and the chuck will likely be really hard to remove! Good luck!
Mar 20, 2012 | Drills
The chuck has been pulled off. Whats the easiest way to reinstall it on my Bosch 11236vs Hammer Drill?
The chucks on the 11236 are designed to be removed, if you were not aware of this it may look like the tool has failed, it has not. To replace the chuck set the chuck back on the shaft of the tool, grip the outer collar of the chuck and rotate it counterclockwise while pushing down .The chuck will drop into a set of grooves on the shaft and lock there, give it a wiggle after to make sure its seated. Sometimes it takes a couple of tries to get it. To remove it just grip the collar turn counterclockwise and pull up, the chuck will come off.
Nov 22, 2010 | Bosch 11236VS Rotary Hammer
How do i remove old chuck from drill
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting if this drill has a 2 speed transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Jul 07, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I have a really old Milwaukee 3/4" rotary hammer, I don't know how to get the bit out, any help would be greatly appreciated
if it does'nt have a keye'd chuck, it may have arubber collar,spary some lube down into chuck and firmly push down,w handle agains't ground or other firm surface
Apr 20, 2010 | Milwaukee 3/4" Rotary Hammer Drill Heavy...
Chuck jaws on Makita 8444D fell out
There is suppose to be a flat head Left hand thread chuck screw in there. It may have fallen out. You will not be able to put the jaws back into the chuck. You will have to replace the chuck with a new one. If you make sure that the chuck screw is not there you can remove the chuck with a couple of steps. Make sure the drill is in it's lowest gear. Use a strap wrench or some large vise grips on the chuck. If there is still one jaw in the chuck make sure it is all the way open and locking the collar to the chuck. The chuck will come off in the regular lefty loosey configuration. It may be stubborn. If this is the case, You may have to cut the collar off the chuck and use a pipe wrench. Or bring it to a professional to get it changed out.
Sep 23, 2009 | Makita 18 Volt Cordless Hammer Drill Kit ...
Drills Logo
194 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
