How to turn on hardware switch to enable wireless
I have an intel PROset wireless software on my computer and it keeps telling me to use the hardware switch to enable the connection.. it says on their site it's fn+f2 but i tried that and on my keyboard fn+f2 mutes the computer.. do you know where or how to switch the hardware switch?
  • 72 Answers
What make, what Model? One of the least standardized items in computing is what/where the wireless switch is.
Posted on Nov 27, 2009
  • patriciaride
    patriciaride Apr 21, 2012
    toshiba satellite P775D s7302
  • 201 Answers
Hold down the fn key and look for the )))) key
if this does not work
are you sure there is a wireless card in the unit, these are also cheap on ebay
Posted on Jul 23, 2009
Can not enable wireless on toughbook cf-52 "radio is off"
Most Panasonic Toughbooks have a Physical On-Off
Wireless Switch Built-In. I belive the one on the CF-52
is located on the front right-hand side hidden behind
the handle. It is a small switch and you must slide it
to the right side (On) as opposed to the left side (Off).
Most modern Toughbooks also have a Wireless Switch
Utility which may be required. If so, you can find the driver at:
http://pc-dl.panasonic.co.jp/dl/search?q=&button=&dc%5B%5D=002001&p1=&p2=&oc=&lang=
That is it. Good Luck.
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989
Oct 07, 2012 | Panasonic Toughbook CF52 Notebook
My everex stepnote laptop will not connect to the internet per wireless now. Will connect via cable. See all wireless connection, but just continue to search and search and fail cnnection. Error message...
You may have a driver problem. First, simply try to set up a new wireless connection. If that doesn't work, try this.
While hardwired go to:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng
(just copy and paste into address bar of browser if necessary, or type it as one long string.
Under "products" choose "wireless networking". Under "Operating System", find your specific O.S.
Under "Download Type", choose "drivers". Then scroll down to find the drivers you need.
Download and install the driver package
If this doesn't work, repost with more information concerning the make, model of your computer, type of operating system, and be very specific. Give as much info as possible
Installation instructions:
Immediate Installation/Upgrade of Drivers on Local Machine
To install or update on this machine now, click 'Install Now' below or use standard OS installation methods
To Install or Update Later:
1. Click Start, Run and then browse to the directory where you extracted this archive.
2. Double click Setup.exe and click OK. Follow the on-screen instructions to complete the install.
3. Right Click on "My Network Places, Choose properties and finish configuring your network.
Manual installation:
1. Click the My Computer and choose Properties, From Hardware tab, choose Device Manager.
2. Right click on Network Adapters and choose scan for hardware changes.
3. The Plug and Play Wizard should pop up. Follow instructions but don't select an Intel adapter from the list. Click on Have Disk.
4. Enter the path to the directory where you extracted this archive and click OK. Then follow the instructions to install the drivers. When the adapter is added, it appears in the Network adapters list.
5. Click OK and then Close. If prompted, restart Windows.
Optional Manual Update
2. Right click on the adapter you wish to update under Network Adapters and choose Properties.
3. From the Driver Tab of the pop up, click the Update button.
5. Follow the on-screen instructions to update the drivers.
NOTE: If you are installing a driver in a computer with existing Intel adapters, be sure to update all adapters with the same new software. This will ensure that all adapters will function correctly.
Troubleshooting
-Make sure that you use the drivers from this archive.
- When updating base drivers, if PROSet was installed, PROSet needs to be updated also. If you have downloaded the minimum Web Pak, you will need to download the full Web Pak to obtain the updated PROSet files before being able to access the PROSet application.
-In your computer's BIOS settings, make sure "Plug and Play OS" is set to YES.
-Make sure the driver is loaded and the protocols are bound.
-Check the Windows* Event Viewer for error messages.
-If you are attaching to a NetWare* network, check your frame type and verify that NetWare client or server software has been installed.
-Test the adapter with the Intel PROSet advanced configuration utility or with the DOS diagnostic provided in the Tools Directory contained in this archive.
-Check with your LAN administrator - you may need to install supplemental networking software.
Intel(R) PROSet II
To start Intel PROSet II, double-click the Intel PROSet icon found either in the lower right hand corner of the screen or go to Start/Settings/Control Panel/Intel PROSET II. To run diagnostics, select the adapter and click the Diagnostics tab, then click Run Tests. For additional information, click Help in the Intel PROSet window.
If this doesn't help go here:
http://www.piriform.com/speccy
Download and install the software. This will tell you everything you need to know about your computing environment that you will need to know to repost the question and get a definitive answer.
Open Device Manager (Start > Control panel > Hardware > Device Manager), look for anything that has a ?, or a yellow triangle w/an exclamation mark ( ! ). Make note of it in your next post.
Good luck
If this helps you resolve your problem, please
consider giving me a rating of 4.It will help me
as well. Thank you.
Nov 26, 2010 | Everex StepNote NC1500 Notebook
Something wrong with software causing wireless connection issues
Make sure you are using the application that came with your computer to work with the wireless card. The windows embedded application is a generic program. The application that comes with your computer/wireless card will work better or is made to work with that adapter. You can turn off the windows wireless zero configuration by going to:
Start -> Run -> Type "services.msc" hit enter
Scroll down to the bottom and right click on Wireless Zero Configuration and click Stop.
Use the Intel PROset Wireless application which are used in most Dells.
If you are stilling having problems, try uninstalling the PROset Wireless Application, Updating the Wireless Drivers and Reinstalling the PROset Wireless App.
This link
will help you
Aug 02, 2009 | Dell Studio 17 Laptop
How do I turn the radio on the wireless card
When your computer is switched on, the WiFi radio is almost always transmitting or receiving signals. In certain situations, as in an airplane, signals from the radio may cause interference. Use the following methods if you need to disable the radio and use your notebook without emitting radio signals.
Use the Optional Computer Radio On or Off Switch
If your computer has an external switch installed, use it to switch the WiFi radio on or off. See the computer manufacturer for more information about this switch. If you have Intel® PROSet/Wireless installed, the current state of the radio displays in the Intel PROSet/Wireless main window and on the Taskbar.
Use Intel PROSet/Wireless to Switch the WiFi Radio On or Off
From Intel PROSet/Wireless, the WiFi radio can be switched on or off. The status icon on Intel PROSet/Wireless displays the current state of the radio.
To start Intel® PROSet/Wireless, use one of the following methods:
  • Click Start > Programs > Intel PROSet Wireless > WiFi Connection Utility.
  • Right-click the Taskbar icon prosettaskbaricon1.jpg located in the lower right corner of your Windows* Desktop to open the Taskbar menu. Click Configure WiFi.
  • Double-click the Taskbar icon to open Intel PROSet/Wireless.
Switch the WiFi Radio On or Off from the Taskbar Icon
To switch the WiFi radio on or off, click the Taskbar icon image1_ipswtaskbaricon.jpg and select WiFi On or WiFi Off.
How to use the Device Manager to Disable the WiFi Radio
The WiFi radio can be disabled (made non-functional) from the Windows* Device Manager.
Note: If you disabled the WiFi radio from Windows*, then you must use Windows to turn the radio on. You cannot use a hardware switch or Intel PROSet/Wireless to enable the radio again.
Windows* XP
  1. From your desktop, right-click My Computer.
  2. Click Properties.
  3. Click Hardware.
  4. Click Device Manager.
  5. Double-click Network adapters and expand the selection by clicking the Plus symbol.
  6. Right-click the installed WiFi adapter.
  7. Choose Disable from the menu.
  8. Click OK.
Windows Vista*
  1. Use Control Panel > Mobile PC > Adjust commonly used mobility settings (if you use Classic View, select Control Panel > Power Options.
  2. Click Turn Wireless Off .
Hope this helps !
Jul 03, 2009 | Acer Aspire 3000 Notebook
Can't find wireless hardware switch
I found someone locally who could tell me where the hardware switch was phyically located. I had thought that this was a software switch, but it's actually a button on the keyboard of the laptop, but it isn't labeled and, since I bought the laptop as a refurb on eBay, I didn't have a user manual to tell me where the switch is located.
May 07, 2009 | MPC Computers TransPort T3000 Notebook
Intel Pro wireless 3945ABG cannot find available wireless network
Did u check if the wireless radio is enabled in the computer or not just make sure the wireless radio is on.....
1st check the hardware switch first....
on the front panel you will see a swith as well as the wireless card indicator for the wireless,just toggle the switch and check if the wireless inicator light is on and off incase the light is on and the switch is turned off do the following step...
2nd click on start go to all program,you will see intel proset click on intel proset and you will see two options now click on intel proset utillity,out here in this box you will see enable radio check if it says the hardware switch is on or off,if it is off choose the option to on and click on apply and ok and then check..
now you should be able to see the network as well as it should be connected to the network...
incase both the hardware as well as the switch was on let me kno what error is it giving while you click to view the network...
it might a possible thing that you need to reset the wireless card.....u might need to take the card in and out from the computer...
best of luck...
incase you are stuck let me know..
vedhick
Jan 31, 2009 | Intel PRO/Wireless 3945ABG Network...
Iam connected to the wireless network but cant access internet
right click my computer
then properties
hardware and then devices
scroll down till you find your network
click it and then update
after updating restart
let me know if that helped
Jan 18, 2009 | Acer Aspire 5315 Notebook
Wireless adapter radio
Windows* XP
  3. Click Hardware.
  8. Click OK.
Windows Vista*
Nov 05, 2008 | Acer Aspire 3000 Notebook
Wireless internet
Just push in on the wifi light Icon on the top of the laptop. It is a light and a switch. The led light will turn orange when it is off and blue when it is on. That's it. Later gater..
May 12, 2008 | Computers & Internet
Intel PRO 2200BG will not detect any network
This IS the solution: Set it to use 802.11b _ONLY_ Do this in Windows: Start->Settings->Control Panel->System->Hardware->Device Manager->Network adapters->Intel(R) PRO/Wireless 2200BG Network Connection->Advanced->Wireless Mode = 802.11b only Driver version: 9.04.36 (04.04.2007) PROset/Wireless Software: not installed OS: Windows XP
Aug 15, 2007 | Intel PRO/Wireless 2200BG 802.11g/b
Computers & Internet Logo
1,646 people viewed this question
David Payne
David Payne
