Question about Vacuums
Dyson, sucks great when using attatchments/hose. Doesn't **** when using traditional beater bar carpet cleaning
    Sergeant:
  • 273 Answers
If beater is rotating then you may have blockage just behind it
Posted on Jul 23, 2009
Fault finding
Have you accidentally switched off the beater bar via the dial on the head? Some models have a 'hard floors' and a 'carpets' setting (which disengages/engages the beater bar).
Jul 06, 2014 | Dyson Vacuums
I have an animal dyson. The front nose dives into the carpet when moving the dyson in the forward motion, fine when pulling back. A huge amount of effort is required to move it forward. Took it to a...
Check bottom plate is corectly fitted.theres no height adjustment on them but they do suck down on longer carpets.u could try switching off beater bar on the side at front that may ease the effort
Apr 10, 2017 | Dyson DC07 Animal Bagless Upright Cyclonic...
I accidentally sucked up part of a blanket with my DC-17 Animal Dyson and now the roller brush makes a griding noise. Did I ruin the clutch or the roller bar. When I lift up on it slightly it doesn't make...
My Dyson started making a loud noise when in "carpet" mode. After reading a ton of forums I thought it was the clutch assembly. Got a new one on eBay for a great price. Somewhat hard to replace, but thanks to this YouTube video, I was able to get it in: http://www.ezvacuum.com/dyson-dc07dc14-clutch-assembly-90025204-genuine-p-1636.html
HOWEVER this did not resolve the issue. I realized the beater bar was not spinning or was slipping. I thought I cleaned it all out but realized you need to take the beater bar out and pop the end cap and clean out the INSIDE of the beater bar (tons of lint and cat hair). I additionally sprayed WD40 in there.
It spins great now and in the end I think that's all I had to do was clean out the cat hair build up inside the beater bar. But now I have a new clutch & belts too. Hopefully won't have issues anytime soon.
Dec 22, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson 07 animale
Check out this YouTube Video:
After reading a ton of forums I thought I needed to replace the clutch assembly. My Dyson was making a horrible noise when in "carpet" mode. Got a new clutch on eBay for a great price. Somewhat hard to replace, but thanks to the YouTube video, I was able to get it in.
HOWEVER this did not resolve the issue. I realized the beater bar was not spinning or was slipping. I thought I cleaned it all out but realized you need to take the beater bar out and pop the end cap out and clean the INSIDE of the beater bar. I additionally sprayed WD40 in there.
Dec 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have an animal and after i turn it on, I press the foot release to turn on the brushnad it doesn't switch over.
Dec 20, 2009 | Dyson DC07 All Floors Bagless Upright...
Dog hair gets caught all the time in the belt drive spool, is there a fix for this other than having to pull it out all the time by hand? I have replaced the belt and the brush but this hasnt solved the...
Dec 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
DC07 works with the hose - but not when upright
Check the actual brush bar is moving. If it is then there's definately a clog and it could well be behind the beater bar. If you can remove the sole plate (which is the grid in front of the beater bar) then undo it and check dirt behind the beater bar, belt and main dust channel. Also check the main inspection air ways and if the beater bar is clogged with hair, clean it off.
Mar 31, 2009 | Dyson DC14 All floors Bagless Upright...
Dyson dc 14
Hi
we had the same problem loads of suction on the pipe but did not touch any thing when in upright mode. The brush bar was rotating but did not seem to be doing anything to the carpet. when we looked at the machine sideways the plate that surrounds the beater bar was not parralell to the floor The front was meeting the foor so from the hoovering position it looked fine but the back was tipping up under the vacuum lifting the brush bar away from the floor and stopping the suction. The only thing that seems to hold this parallel when in hoovering mode seems to be the connection hose from the beater bar into the cylinder (Clear plastic with spirals). This seems to act like a spring to hold the plate paralell. We twisted this through 180 degrees and flexed it a bit and it is now holding the plate parallel. Bingo! beater bar is connecting with the carpet and we are back to great performance. Could not believe it could have such an effect
Our machine is several years old so we might have to get a new hose. However there are no splits in it so we might try a bit of duct tape repair if it goes again as it only seem to be the rigidity of the hose thats rhe problem not the connectors.
Hope this helps
Dec 26, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
Nov 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
48 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
