Question about Acer Aspire One AOA150-1784 Netbook
My Aspire One Netbook doesn't charge the battery
I even bought a new battery and installed it. No luck. As soon as I unplug it, it loses power.
  • 201 Answers
Check the ac adapter, the plug on the end may be bad
also the pin in the dc jack ,if you can move this pin
just a little bit, the connection can be broken
new jacks are cheap , if you want to do this yourself
you must take apart
Posted on Jul 23, 2009
My Acer aspire one just stopped working for no reason. I plugged it in to charge it but none of the lights come on, and nothing happens when I hit the power button...
Assuming that the AC/DC Power Adapter is not faulty no LED lighting up at all and no image at all on the screen might mean a power management fault on the motherboard.
First try removing the battery underneath the netbook. Then connect the netbook to the power cable without the battery installed. If the netbook powers up without a battery installed then the battery is probably faulty most likely with completely depleted and unchargeable power cells. if so you will almost certainly need a new battery and some little known guidance on the correct management of a netbook or notebook battery (see below). Dead batteries tend to generate a more than normal amount of heat.
If the AC/DC adapter is not faulty and using the netbook without a battery does not help then check the DC power jack where the power cable connects to the netbook to see if the jack is loose or detached from its original solder point on the motherboard.
If the none of the above are the cause of the problem then the motherboard probably has a power track or capacitor fault which might be repairable (as would a loose DC jack) but these types of fault even if successfully repaired can easily come back and the cost of repair might be high compared to the value of the netbook and not worth it since a brand new state of the art netbook with a full warranty would not be very expensive.
Many users take an incorrect approach to netbook/notebook/laptop battery management. These batteries are rechargeable and are only supposed to be connected to the power cable when their cells are low or depleted. Once the cells are fully charged the power cable should either be disconnected and the computer used on battery power alone or the battery should be removed and kept for when battery powered use of the computer is next needed.
Once a fully charged battery is removed the computer can be used directly connected to the electricity without the battery installed.
A disconnected battery needs to be reinstalled and recharged from time to time if it is stored for long periods of time, because the charge in its power cells very slowly dissipates even if is disconnected from the computer.
Nov 08, 2011 | Acer Aspire One Netbook 8.9" Notebook
Acer netbook loses power, turns itself off
I would get the battery first. But worst case you have a bad power connection on the board that needs to be resoldered or replaced.
Apr 14, 2010 | Acer Aspire One AOA150-1784 Netbook
Acer Aspire One battery not charging
your probably going to need a new battery
Mar 25, 2010 | Acer Aspire One AOA150-1784 Netbook
AC lead on my Aspire One 531 dead?
Is it totally dead?Can you charge it?
I am not sure what you need.If the charger is bad and will not charge the battery replace it.
Good luck
Mar 22, 2010 | Acer Aspire One PC Notebook
Acer aspire one D150-1Bw battery not charging
the battery is gone dude. This year manufactures have reduced the quality of batteries drastically to cut down the costs and i think u got even the worst of them.
and whats more they they dont even give warranty on batteries for more than 6 months.
so U'll have to get new one. Sorry
Jan 05, 2010 | Acer Aspire One PC Notebook
Advent Netbook 4489
IT sounds like you need to replace your battery. If your laptop (notebook) is working properly while plugged in with Ac power we know it is not your power supply.
I would visit the manufacturer's website for replacement batteries. One complaint I have read about over and over on these particular systems is that the battery life is very poor.
Sep 17, 2009 | Advent Netbook
Netbook acer one not recharging the battery
Your charger might be dead, check his output with a voltmeter if you get some juice. It should be around 19 Volts. Then it might loose his power with a charge (when you plug it onto your laptop) so you can try to connect a car light bulb to it . If get light then probably the motherboard of your laptop has issues, if no lights then you can replace your charger.
Cost in average 45 USD.
good luck
Jul 31, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One AOA150-1784 Netbook Logo
519 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
