Question about Kenmore Dishwashers
Wont fill with water, replaced the inlet water valve,still wont fill
    Scholar:
  • 86 Answers
First of all make sure the water shut off is on. Second check the water float is it jam on the top position that will shut off the water. then the timer switch that control the water inlet valve.Hope this 'll help. God Bless. have a nice day.
Posted on Jul 29, 2009
2 Suggested Answers
  • 574 Answers
SOURCE: mACHINE WILL NOT FILL, HOW DO i CHANGE INLET VALVE
most inlet valves are near the front of the washer. The kick panel at the front of the dishwasher should have several screws holding it, take those out ant the kick plate should come off where you can get to the valve. Look under the sink cabinet and you should see two vertical water lines and one horizontal line. The one horizontal line runs through the side of the cabinet to the dishwasher it should have a shut off valve on it close the valve and that will cut off the water going to the dishwasher. Have several towels ready because there will be water left in the line. Either unplug the dishwasher or turn off the breaker for the dishwasher before working on the valve Place a towel around the area of the inlet valve and disconnect the line coming to the valve. Should be a couple of screws holding the valve to the washer. Disconnect the electrical connections and remember where they go. Take valve out and reverse the procedure for installation.
Posted on Jan 07, 2010
Testimonial: "very helpfull, but ithink the valve is at the rear of my machine"
How to fix amana w10240534c washer wont fill?
check your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. no fill If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
May 31, 2014 | Amana 3.2 cu. ft. Top-Load Washer
My washer wont fill up or spin on spin cycle. its not a front loader
SOUNDS LIKE A BLOCKED HOSE SOMEWHERE OR OBSTRUCTION IN WATER PUMP
Apr 08, 2014 | Frigidaire Washing Machines
My whirlpool dishwasher wont get water to it when I press start
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Sep 16, 2011 | Whirlpool Dishwashers
Water wont go in washer when on cold /cold or warm cold but will fill on hot cycle. Only cold water is connected. i dont even have hot hose connected---has worked fine for a year on cold/cold. Now has a...
The inlet valve on the cold water inlet is clogged, dirty or jammed. You need to remove the inlet valve and clean the valve and filter. use back flushing with brushing to clean the filter.
the hum you hear is of the coil working but is not opening to allow water into the system.
Also you can switch the inlet valve from the hot line if needed .
check this link for removing the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Sep 13, 2011 | Washing Machines
My washer wont fill with water what seems to be the problem
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 10, 2011 | Samsung WF210AN Washer
Dishwasher wont let water come in
Hi
Daniel
Jun 19, 2011 | Dishwashers
Baumatic starts but wont fill BKD45W model
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back for any further assistance.
Daniel
Dec 10, 2010 | Baumatic 23 in. BDW8 Built-in Dishwasher
Washing machine wont stop filling with cold water
Since you removed the screens, the sand probably has entered the valve and damaged the spool. It's apparently sticking open. You need to replace the complete valve and keep the screens in place.
Jun 09, 2008 | Whirlpool LSR5132PQ Top Load Washer
The cold water seems blocked and wont fill up the machine. What do I need to do?
if no cold water then check the water inlet valve for possible obstruction at screen in the valve or the fill hose it may have a screen in it
if not the problem the verify that you have voltage to the water valve if you do replace the water inlet valve
Apr 21, 2008 | Washing Machines
Dishwashers Logo
184 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
