Question about Carrier 38CKC036 Air Conditioner
Air Conditioner shut off
My unit comes on for about 10 or 15 minutes then shuts off again, I will push the reset button and the same thing happens
  • 22 Answers
Hello friend without physically seeing your unit it's going to be hard to fix that as it could be kicking of for any number of reasons most of which are designed to protect your unit. One thing that you can check is the condition of your coils. If the outside coil is full of dirt then it will cause the unit to turn off because of high pressure and if the indoor coil is dirty then the coil is being insulated from the heat that it is suppose to be picking up and thereby causing a low pressure situation causing the unit to go of because of low pressure. These are just a couple of things that could be wrong, my advice would be to find an A/C company that you trust and get it fixed before it really gets hurt. Hope this helps 2rns4u <*{{{>(
Posted on Jul 23, 2009
LG air conditioner will not turn off. I push the power button, air stops but ,something keeps running. Any clue as to why it's happening?
Did you try flipping the breaker to see if it shuts down? Resetting the unit may fix your problem. If you need more questions for your Air Conditioning Repair needs, check us out online.
Jul 11, 2017 | LG Heating & Cooling
My airconditioner on my 5th wheel comes on, but no fan or cooling happens
take it to an air conditioner repair shop it possibly needs recharged
Jul 17, 2015 | Dometic Rooftop RV Air Conditioner
Horrible awful noise coming from carrier heat a/c wall unit!
I watched your video on youtube. Sounds like a seized compressor. Do you know if it is reverse cycle or electric heat?
Jan 18, 2010 | Carrier 52PQ307 Wall/Window Air...
My LG window ac continues to shut down after 20 or 25 minutes
The button on the plug is a GFI. Ground fault interuppter. Like on your hair dryer. When the unit is running, or has just tripped out, feel the plug and the well receptical. If either feel warm or hot, do not continue to run the A/c unit. Get an electrician to check for a faulty/ worn/improperly wired outlet. The units tripping out for a reason.
Aug 01, 2009 | Samsung AW0603B Air Conditioner
Outside fan not working
Replace the fan motor capacitor and try again.
Jul 05, 2009 | Ruud Central System Air Conditioner
Reset air conditioner
Unplug it. Wait a few minutes. Hold in the Power button while plugging it back in and keep the button held down until a beep is heard (~5 sec). Unplug the air conditioner, then plug it in again.
Note: some units require using the Mode switch, rather than Power.
Aug 09, 2007 | Sharp AF-S100FX Air Conditioner
"Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Aug 03, 2007 | Sharp AF-S85FX Wall/Window Air Conditioner
Air condition problem
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The manual says to clean filter and unplug unit, then plug unit back in and code will be reset.
Aug 02, 2007 | Sharp AF-S120FX Air Conditioner
Carrier 38CKC036 Air Conditioner Logo
200 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
