The T.V. only has one audio out jack on the back it is digital audio output jack
    Problem Solver:
  • 12 Answers
If you are sure that is a digital out, then plug it in a digital input of your receiver.
Posted on Jul 23, 2009
What can be connected to te audio output jacks on the back of this set?
You didn't include make and model TV; so only generalized answers are possible.
Typical RCA phono jacks like those shown in the blue box of the stereo amplifier below:
25998201-ac5bgneb45fvu53muoueauti-3-0.jpg will accept cables to connect to other audio devices. The audio RCA jacks are color coded RED (right) and WHITE (left) for low level stereo signals. Some have YELLOW jacks for Standard Definition video, ORANGE jacks for AC3 Digital audio and newer amps have HDMI jacks.
Connect the TV's audio OUTPUT jacks and a stereo pair of unused audio INPUT jacks on the amplifier with cables that have ends that match each. Turn on the stereo & TV and select the input on the amplifier that matches the stereo pair of inputs you used to connect to the TV. Adjust the volume to hear the audio over your stereo system's speakers.
Use the HDMI or AC3 sources for superior audio - including 5.1 (or better) Dobly Digital when possible. Otherwise, a standard 2 channel stereo program will be heard.
I hope this helps & good luck!
Dec 08, 2015 | Televison & Video
How to fit a sound bar to a proscan tv
1) Go the Sound Tab on the remote's Proscan menu
2) Set the system's "Digital Audio Output" to PCM (pulse code modulation)
3) Connect a coaxial cable from the Coaxial "jack" on the back of the TV to the Digital Input "jack" on the back of the sound bar.
It should work now!
Feb 05, 2015 | Proscan Televison & Video
I HAVE A SANYO LCD TV dp42d24. wANT TO ENHANCE SOUND WITH EXTERNAL SPEAKERS. THE RED/WHITE ON THE TV BACK SAYS audio input. i WANT AUDIO OUTPUT
There's probably a digital audio output you can use if you have a digital receiver. If you don't have a digital receiver you can take the audio out from the cable box or satellite box. Since I have an old analog receiver it's the way I connect my equipment. I use a hdmi cable for the TV so it frees up the rca output jacks on my cable box. Works great.
Aug 25, 2014 | Televison & Video
How to output sound to a 2nd device
If you need an analogue output, you can tap stereo analogue audio by using one of the two sets of "pre-out" RCA jacks on the back of your receiver. These provide "headphone like" output power, and will not overload any analogue input connected to it EXCEPT MIC and PHONO inputs on the 2nd device. If it's digital audio output you need, there's an HDMI monitor out, that will provide digital audio to another HDMI input equipped device. You'll have to get a relatively cheap adaptor if you need this digital audio output in another digital format/connection (like the popular S/PDIF optical or coaxial).
Jun 11, 2014 | Marantz NR-1604 7.1 channel HT receiver...
My 26 inch Panasonic Viera TV has what looks like a headphone jack on the side of it but when I plug headphones in the sound still comes through the TV speakers. How do I get the headphones to work?
Check you USER MANUAL to make sure it is actually a headphone OUTPUT jack and not a digital INPUT jack.
If your tv does not have a headphone output jack you can always get an adapter that plugs into the red and white AUDIO OUT jacks in the back.
If you want to turn off your tv's speakers, go to the MENU.
Then go to AUDIO then select SPEAKERS OFF.
Good luck and please post back with how you make out.
Jan 24, 2011 | Panasonic Televison & Video
I need to know the type of audio cable to use with the Altec Lansing BX1021 2 speaker system.
COAXIAL DIGITAL JACKS;
{COLOR OF RCA COAXIAL CABLE CAN BE DECEIVING THIS CABLE CAN BE A BLACK, ORANGE, ETC.} IT'S BASICALLY COAXIAL -- OUT & IN..
http://www.crutchfield.com/S-S7N8XMJitvh/learn/learningcenter/home/connections_glossary.html
**ABOVE IS THE URL ADDRESS WHERE I FOUND THIS INFORMATION COPY AND PASTE TO YOUR URL BAR AND DISCOVER THE WORLD WIDE WEB
This type of jack is used for the digital audio inputs and/or outputs on A/V components such as receivers, CD players, DVD players, and more. Coaxial digital jacks are also sometimes found on higher-end PC soundcards for digital audio input and output.
Coaxial digital inputs and outputs use standard RCA-type jacks (so coaxial digital cables are terminated with standard RCA connectors). But the cable itself is specially designed to handle the much wider frequency bandwidth of digital signals
**** ~ Where did I find this information here is the URL Address where this information was found. ~ ****
Dec 07, 2010 | Altec Lansing BX1021 2 Speakers
How do I conect external radio/speakers to my lg 42lh40-ua
There are many options here. Most HDTVs today have analog audio and digital audio output jacks. You can use RCA audio cables or a 3.5mm connector, whichever your HDTV has to connect the analog stereo output of the TV to any number of devices such as a stereo/amp which has speakers attached. You could also connect an FM transmitter to the TV and send the audio wirelessly to a nearby FM radio, boombox, portable etc. Most HDTVs today have a digital audio output, typically optical, which uses a digital audio cable ($15) to connect to a surround sound receiver. You can also connect the stereo analog output jack on the TV to a 2.4GHz transmitter and receiver speaker combo to get wireless audio outside, in a swimming pool and so forth, all around the house using wireless speakers. These setups usually cost around $150 or so. Look for the jack on the TV labeled AUDIO OUT and see if it is the white and red 2 jack ports or the smaller 3.5mm single jack port. Adapter cables are available at Radio Shack for around $10 should you need them. So you see the options are almost endless.
Aug 17, 2010 | LG 42LH40 LCD TV
Does the Insignia ns-2brdvd digital opt. output work with HDMI
Below is what your manual says abour it. From hardware perspective, when you have a disc in there the optical audio driver is active and so is the HDMI audio. To verify, lift the lid on the optical interface and you will see a red or blue light on the inside. Don't look directly at it! View from the side.Plug that into your home theater system, select that input on your home theater and you should be good to go.
Insignia NS-BRDVD Blu-ray Disc Player
www.insignia-products.com
Connecting a digital audio optical system
To connect a digital audio optical system:
1Make sure that your player and the TV are
turned off.
2Connect one end of a digital audio optical
cable (not provided) to the DIGITAL OUT
(PCM/BITSTREAM) OPTICAL jack on the
back of your player.
3Connect the other end of the cable to the
DIGITAL AUDIO OPTICAL INPUT jack on
the digital audio system.
Aug 11, 2017 | Televison & Video
Digital audio out jack
That output only works with digital signals (digital tv channels and digital audio from the hdmi in jack).
The HDLCD2600 has no analog out. Sorry.
Aug 14, 2008 | Sansui HDLCD-2600 26 in. LCD Television
LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
Sep 12, 2007 | Digital Audio 5-OUTPUT COMPONENT VIDEO...
Televison & Video Logo
309 people viewed this question
Top Televison & Video Experts
Electro Med Services...
