Question about Makita MAC5200 Electric Powered Air Compressors
I have a Sanborn 60 gallon vertical compressor ( Blackhawk 5 hp ). What weight oil goes in the crankcase?
  • 142 Answers
You must use a compressor oil for that
You can pick up a bottle at Home Depot or Lowe's
Posted on Jul 23, 2009
    Genius:
  • 1,071 Answers
There is actually air compressor oil available at most hardware stores be sure it is compressor and not air tool oil
Looking for manual for sanborn B51-A24-80V1 model
PDF]Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1
intrigante35hindu.strictlyyouth.org/rzsatzo_sanborn-black-max-5hp-air-...
Jul 16, 2015 - Sanborn Black Max 5hp Air Compressor Manual B51 A24 80 1 ... Black Max Portable Air Compressor - 5 gallon Item #: 81527 ' Model #: BS0880504 ...Compressor Manual: $4.95: Buy Now: B51-AT24-80V,B51-A24-80V1.
Aug 28, 2015 | Air Tools & Compressors
How to convert wiring on air compressors 230v to 115v
Unless the motor is designed to work with either voltage it can't be done. If it is, the wiring should be labeled on the motor.
Aug 06, 2014 | Sanborn 60 Gallon Vertical Stationary Air...
Mix oil and water on motor
Ok, sounds like you are having water vapor condense in your crankcase, must be pretty humid where you are.
1- Make sure the crankcase has a vent on it somewhere.
2- Be sure you are running the compressor long enough to get the oil hot enough to evaporate any water that does get in there. If the compressor is over sized and just runs a few times a day it may not run long enough to flash off the water that does collect.
3- That unit looks pretty big if you sized it to spray paint with it may be way too big for your normal shop use (see 2 above).
Nov 08, 2013 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
How big is the oil tank.
There is no oil tank. The oil is in the crankcase of the compressor
Apr 10, 2013 | Bel Aire Compressors Bel Aire 5 Hp Air...
What causes compreesor to blow oil plug and breather filter while running
Sounds like you have a cylinder bad and the compression is blowing by the piston or rings and building up in the crankcase. This what they call blow by on a car engine.
Apr 24, 2012 | Campbell Hausfeld G5396 7 Hp 60 Gallon...
My air compressor gets HOT when you run it for 10 to 15 mins. ,I mean HOT,not the motor but the compressor pump and it kicks the breaker.I have a 6.5 hp 80 gal. Black Max two stage pump by Coleman, can you...
Sounds like you have a rod or maybe a bearing bad or possibly a piston starting to seize. Maybe all may be on the way out. Have you checked the oil. Is it at the proper level. These units are not pressure lubricated but splash lubricated. So when the rod goes to the bottom of it's stroke it hits the oil in the crankcase and splashes oil thru out the unit. (simply explained) Also if these units are only used a short time condensate can build in the crankcase. Then you're trying to lubricate with water. If it's binding bad enough to trip the breaker I would say it's to late to try and save. Unless it's still under warranty the only solution is to disassemble and repair,or replace depending on the damage done. Good luck!
Jul 25, 2011 | Coleman 6.5hp - 80 Gallon Vertical ASME...
We have Ingersoll Rand Type 30 Reciprocating Air at about 20years old.. what type of oil is used in the crankcase?
Almost all compressors use sae 30, you can buy it labeled compressor oil. The key is compressors use a non detergent oil.
Mar 07, 2011 | Ingersoll Rand Type 30 Reciprocating Air...
We have a T30 Air compressor and we found this compressor full of water inside the crankcase, where the oil is. and know when we turn it ON it start crearing presure inside the crankcase. do you know what...
As you probably already know when you compress air, the moisture in the air falls out and ends up in your tank. If you're rings are going bad, and allowing blow by into the crankcase, the moisture will go with it. Two things happen, first the water displaces the oil which rises to the top and probably goes out with the air,and secondly then the bearings and cylinders don't get lubed, and wear even more. You will probably require new rings, and depending on wear, boring and new piston(s)
Sep 24, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Should I lay the compressor on its side?
I would advise you drain the crankcase of oil before you do that.
Jan 27, 2010 | Coleman Powermate 60 Gallon Air Compressor
Oil comes out thru crankcase vent
sounds like piston ring blowby or a broken piston, teardown will reveal the broken parts.
Jan 25, 2010 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
Makita MAC5200 Electric Powered Air Compressors Logo
707 people viewed this question
Top Makita Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Makita Air Tool and Compressor Expert? Answer questions, earn points and help others
