Question about Craftsman Garden
I have a dlt3000 18.5 intek. After 15-30 mins of mowing the engine sputters and dies. I can shake the mower erratically while it is starting to die and it stays alive, but as soon as I stop it dies. I can immediately restart and idle fine, but as soon as i engage the the blade or gear it wants to sputter and die again. Thanks for your time!
  • soldierstix Jul 26, 2009
    i have replaced the coil pack,fuel pump,fuel filter, and spark plug and still has the same problem.
  • 475 Answers
It kinda sounds like a fuel pump or fuel delivery problem
Posted on Jul 25, 2009
  • Wade Mobley
    Wade Mobley Jul 26, 2009
    check the safety switches one under seat
Just received my model 247.290001 mower was mowing when engine dies and will not turn over now
Did it stop suddenly? Or splutter and cough like an engine problem? If suddenly I'd suggest checking the seat switch wire hasn't become disconnected, if this doesn't solve it then check all the other safety switches.
Aug 14, 2015 | Sears Garden
Mower dies after 5 min. of mowing
check for spark when the engine dies you might have a bad coil
Aug 15, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
My parents have a self propelled...front drive...walk behind 22in cut mower purchased at Home Depot 3 seasons ago.....I do the maintance on the mower....sharpen blade....change the oic/plug &...
Does the mower die right away (cuts out) or does it sputter to a halt. Sputtering out would indicate a fuel problem. If it just cuts out when hot, then more likely an ignition problem. Your coil may need replacing. Take a close look at the coil wire (spark plug wire) and its routing. Make sure it's not touching part of the engine where it's heating up and has caused a "leak" to ground it out when it gets hot. If all is well then check your spark when the engine is hot and cuts out. Make sure you have a very good blue spark and not a weak one (check it cold first and then compare!). Again, indicating a possible ignition coil problem. Hope this helps and best of luck to you.
James
Sep 14, 2011 | Toro Power Lawn Mower
Mower will start up cold, i will mow for a half hour then it sputters and dies. After it sits for a while and cools it will start again, but not as easily as the first time. It will again mow for a while...
The valves DO NEED adjusting every 250 to 300 hours of service. That is why it dies out beleive me. It is not that hard to do if you have a service manual to help you along to perform this task
Jul 09, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Cub cadet RZT 42 shuts down after about 30 min of mowing.
Check your magneto. I have had them cease to function whenever they would get hot. When cooled down, they would work.
Jul 23, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Lawnmower was overfilled with oil.It has not run that good since,but I could still mow my lawn with it. Then later on it started to die out. and it won't keep running. I had it looked at, and it still...
It may have damaged the piston ring lands (grooves) by slapping the piston with oil. If you have the compression tested it will tell you a lot, the mower should be around 100 - 120 psi, anything less and the engine is likely not worth repairing, if you like the mower buy a short block.
May 31, 2010 | Parks Optical 13.5hp Briggs And Stratton...
Husqvarna 2009 Tractor Run 30 minutes, sputter, loses power, dies
hi it seems to me either a lack of compression when she is warm /hot /check tappets or a weak mixture /air leak on the inlet someware hope this is of some help merlinv12
Aug 20, 2009 | Parks Optical 13.5hp Briggs And Stratton...
Sputtering Mower
It might not be disengaging the mower deck all the way off. I had this problem on an older model.
May 20, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
554 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
