Have 46 samsung dlp that has green lines all over the screen . menu still works but doesnt go away on the menu mode. the green is so thick that you cant see any picture in the background.
    Novelist:
  • 133 Answers
Red, green, or blue retrace lines ( a quote from "Notes on the Troubleshooting and Repair of Television Sets", found at http://www.repairfaq.org/sam/tvfaq.htm#tvrgbrlin )
Where only one color is showing, suspect an incorrectly adjusted individual background/bias control or bad part on the CRT neck board for that color.
  • Individual brightness/background/bias control(s) - mark setting of pot for the problem color and then see if a slight adjustment removes the retrace lines. See the chapter: "TV Adjustments". Of course, if this happened suddenly, the problem is not due to a misadjusted control though a dirty pot is possible - turn it back and forth - this might clean it and restore normal operation.
  • Component or connection on CRT neck board - insufficient voltage to or incorrect biasing of the video driver for this color can result in the CRT never totally blanking. Compare voltages and signals, and swap components between good and bad channels to confirm.
  • Blanking circuit - this may be a part of the video/chroma chip or separate. Check and compare waveforms of good and bad colors to determine if the blanking pulses are making it to the video output.
There is a slight possibility that a bad CRT may result in visible retrace lines. To eliminate this possibility:
  • Disconnect the filament - all evidence of a picture, raster, and retrace lines should disappear once the filaments/cathodes have cooled (15 seconds or so. If there are still visible retrace lines, the CRT is suffering from cold or field emission from someplace (may not even be the cathode).
  • Turn down the screen (G2) control on the flyback (usually). If one color remains no matter how you set the control, again there is some kind of weird emission from the CRT. However, if white/gray retrace lines remain, the problem may be in the screen supply.
(quote ends)
You will be greatly helped if you have a schematic for your TV set, and you may need to change some parts, clean some connector contacts and/or tweak settings inside the set, so remember the original settings before you tweak them...
Good luck
3rq8 (Triarcuate)
Posted on Jul 23, 2009
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Green Lines on Samsung DLP
Either bad capcitors, or (if you're lucky) the color wheel needs lubed up. Probably bad caps.
Jun 12, 2012 | Samsung Televison & Video
Yesterday my 46" dlp samsung
you can not solve this by your self you must have technication to open the set,,,thir must be some thing wrong,may be deg plug had moved from its place
Dec 23, 2010 | Samsung DLP HL-P5663W 56" TV
Black line down lefthand side of screen about 1" thick
The monitor is old. It could be slightly adjusted. But when you start getting lines, soon the image becomes blurry, and during CRT death the Cathode Ray Tube radiates 100 times the radiation of a healthy monitor.
Sep 06, 2009 | Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP...
Green shade color on screen over tyhe program that is been broadcast
its a loose connections to you color amplifier RGB. cold solder in that board section.
May 30, 2009 | Samsung HL-R6167W 61" HDTV
Green lines on screen
your power moudle is bad. check for swollen or burst electolytic capacitors
Nov 11, 2008 | Samsung DLP HL-P5663W 56" TV
Hlp4663w color wheel
Check
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Jan 29, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
638 people viewed this question
Top Televison & Video Experts
Electro Med Services...
