Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
No spark just put on new battery new coil and spark plug
  • cwalker121 May 11, 2010
    make sure your ground is good and maybe check the gap between your coil and magnets. usually about 2 pieces of paper thick. ya know, the thing of a bob?
    Sergeant:
    Champion:
  • 320 Answers
I've worked on small engines all my life and have always used a 3X5 index card to set the gap between coil and magneto.
Blessings
Posted on Jul 26, 2009
    President:
  • 1,273 Answers
Also make sure that your battery is installed correctly. Red to POSITIVE (+) and black to NEGATIVE (-).
Regards!!, --W/D--
Posted on Jul 24, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: 2000-2001 craftsman 20.5 twin cylinder riding mower no spark.
Possibly the safety switch under the seat is faulty.
Posted on Apr 10, 2013
Hi, my zzr1100 will turn over but I have no spark, I have replaced both coils with new ones, replaced - fuse box, CDI,pickup coil and put new plugs in. Can you tell me what's up..... Thanks Anthony.
Hi, Anthony if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
http://zzrbikes.com/threads/59960-ZZR-1100-CDI-problem
zzr 1100 Workshop Visordown
http://motorhead.jactup.com/ZX-11/tech/ZX11_Service_93_01-converted.pdf
Feb 02, 2016 | Motorcycles
No spark at the spark plug
Check first if your battery got a full charge, or not drained...
Let me know..
Jul 18, 2008 | Lite On Spark Plug Lite Green LED
I have a cpi Oliver City 50 it needed a coil pack because there's no spark so I've put a new coil ht lead and plug still no spark anyone know any thing about these bikes??Any help much appreciated ??
Hi, Anonymous if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
For more information about your issue, please visit the websites below. Good luck and have a nice day.
Free CPI Motorcycle Service Manuals for download
Nov 16, 2015 | Cpi Motorcycles
Why are we not getting spark to the 3 coils ?
Is the battery all you replaced..?...What did you check the coil power with...Is it power to the coils or power from the coils to plugs....?..
Feb 21, 2015 | 1992 Oldsmobile Silhouette
No spark from coil
charge the battery fully it may not have enough charge to start, you could jump start it with a battery or a car but not a running car, they put out 16 volts and will fry the electrics,
Jul 28, 2014 | 2011 Kymco Downtown 300i
2004 Honda Ruckus no spark
Hi, Justincollin and the usual suspects are:
2. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead-acid batteries.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting/leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty pulse coil.
8. Faulty CKP, CMP, or BAS sensor.
9. Faulty ignition switch.
10. Tilt sensor needs a reset.
11. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
2011 Ruckus with no spark Scooter Doc Forum
Honda Ruckus No spark no electrical anything
https://scootergrisen.dk/scooterhjemmeside/download/honda_zoomer_servicemanual.pdf
https://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda
Mar 21, 2013 | 2004 Honda Ruckus Base
TVS scooty pep plus not starting, changed with new new battery & new spark plug - no spark coming (I have tested the spark plug connected outside touching scooty metal body & start-kicking)
Possibly a bad ignition coil. Check the connections at the ignition coil,make sure they are clean and tight, If so,..then most likely either A: the ignition coil is bad,or B: the pickup on the stator rotor is bad or the rotor could be rusted on the raised portion where the pickup get its signal.
Aug 29, 2012 | 2010 TVS Scooty Pep
1997 harley davidson flhtcui no spark
Hi Anonymous, if you have a CKP sensor it needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
2. Battery voltage below 9 volts, loose or broken battery cables especially "GROUND" cable to frame.
6. Failed CKP, CMP, MAP or BAS sensor.
8. Security alarm failing to disarm.
For a prime suspect please visit the website below. Good luck and have nice day.
Apr 04, 2012 | Harley Davidson Motorcycles
I have a 2000 harley davison sporster custom i have changed the spark plugs i have no spark at all the coil is new and the module is new but someone cut my turn single wires and put in new turn singles now...
Hi Altonbaker81, the CKP sensor needs compression to send correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in head. If still not getting spark the usual suspects are:
2. Battery voltage below 8.7 volts, loose or broken battery cables especially ground cable to frame.
For a prime suspect please visit the website below and good luck.
Harley Davidson Sportster error codes and how to access them
Aug 03, 2011 | 2000 Harley Davidson XL 1200 C Sportster...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
163 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
