SOURCE: BRAND NEW BOTTLE WARMER
If they got it at a store, return it as defective. It should be simple to operate, manual or not.
Also the store may be able to give you a copy of a product instruction sheet. You don't say what brand it is.
SOURCE: Honeywell PRO TH4110d Prog Thermostat not responding
cfheck to make sur ethat the t-stat is set for your type of heat. if you do not go through the instructions sep by sep then you will have problems. if you have then call a professional.
SOURCE: I purchased a 2005 home that was vandalized. It
They will work, most zone controls only require the use of 1H/1C thermostats, the system stages and functions are controlled by the board itself.
http://customer.honeywell.com/TechLit/pdf/PackedLit/68-0237.pdf
SOURCE: brand new unit. worked great for 2 days. now unit
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
