Question about Weiser Lock POWERBOLT ELEC DEADBOLT
New combination I need to reprogram the combination on my keypad lock?.
    President:
  • 704 Answers
Here's a free manual you can print out with complete installation and programming instructions you can keep for addressing any other concerns you might have in the future.
I thought this might be easier for you to work from, since you might have to reset the lock prior to entering in your master code and other user codes, etc.
It is easy and straight forward to program and use.
http://www.smarthomeusa.com/Products/ED1460XXXX/manuals/WeiserLockPowerbolt1000-manual.pdf
Hope you find this Very Helpful - Best regards!
Posted on Aug 19, 2009
Where can I get a programming manual for this product? I have the codes but have misplaced the manual and need to change the lock combination.
This link will take you to the page that you need to get started:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Then scroll down to this heading on that page:
Electronic Security-Keypad Deadbolt BE365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that programming code that you found on the backside of the keypad.
A note about the PDF files: If you cannot view a given file, you need to first install Adobe reader. You can get the free download from here:
http://get.adobe.com/reader/
Aug 14, 2011 | Schlage BE365-CAM BE365CAM716 Aged Bronze...
Want to change entry code on lock./
Reprogramming FE 375:
This link will take you to the page you need, to get started:
Electronic Security-Keypad Entry Flex-Lock...
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This is useful because there should be a sticker to be found on the backside of the keypad, with the code number that you need to reprogram the lock. This installation video (fourth item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery!
The ninth item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
Aug 06, 2011 | Schlage FE575-CAM-ACC FE575CAM505ACC...
How do i change the code on my schlage BE365. I want to delete my current one and add a new one
You confused me about which model-the FE575 or BE365 lock that you are dealing with, but that's no problem. The information for either can be found on the same page.
Reprogramming FE575:
Scroll down to this heading on that page:
Electronic Security-Keypad Entry Flexlock...
Reprogramming BE 365:
The seventh item under that same header is a video which walks you through how to reprogram the keypad to your new code, using that program code that you found on the backside of the keypad.
Jul 01, 2011 | Schlage FE575-CAM-ACC FE575CAM505ACC...
Nedd to reprogram security code
Jun 01, 2011 | Schlage BE365-CAM BE365CAM505 Lifetime...
I need the program code to add a door code
May 24, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
Need to change lock code but lost instructions. BE365 PLY 716
May 21, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Do I have to reprogram my lock after changing the battery?
Does the Schlage Keypad Lock or Keypad Deadbolt need to be reprogrammed after changing the battery? The Schlage Keypad Lock and Keypad Deadbolt does not need to be reprogrammed after replacing the battery. All settings are retained in the memory of the lock, including valid user codes and the programming code.
I'm including a link to the pdf file of the complete installation and programming instructions:
http://consumer.schlage.com/Project%20Documents/P515-859.pdf
You may also find more useful information on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx#1
Apr 05, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
The lock quit working (no lights on keypad) I installed a new battery but it still doesnt' work. The keypad doesn't light, like it is not getting any power. I checked all the connections?
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspxThen scroll down to this heading on that page:
Here is the contact info you need for customer service:
Schlage Lock Company
Customer Service Department
2119 E Kansas City Rd
Olathe, KS 66061
United States Customer Support
Warranty & Technical Information: 1.888.805.9837
Mar 21, 2011 | Schlage Camelot Deadbolt Keypad, Satin...
My lock has no combination/ i don't know what the combination is. How can I reset the code
How can I program my electronic keypad lock when the instructions with the programming code have been lost?
The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This number is the programming code referenced in the information for changing the entry code.
Electronic Security-Keypad Deadbolt 365
There's a wealth of info under that heading. You will be able to see a PDF file of the original print instructions, as well as a video of how to install the lock. This installation video (second item down) will be useful to allow you to disassemble it and view the sticker. This is also a great time to change the 9-volt battery! Batteries should be replace about every three years.
Good luck--and please provide feedback if this helps!
Nov 03, 2010 | Schlage BE365-PLY BE365PLY626 Satin...
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
450 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
john h
ray gallant
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
