Question about Refrigerators
Right french door 1/4 lower than left - Refrigerators
    President:
  • 1,124 Answers
Unscrew the hinges and move one up or down a 1/4 inch
Posted on Jul 23, 2009
I have a Maytag french door refrigerator Model is MFI2568AES Serial is 10039560JL. The refrigerator doors do not close properly because they are not aligned. The right side door has a bottom hinge...
Thank you for taking the time to explain this issue. I would need to see pictures of the part you have to compare to the diagram and determine your next move. I would with parts companies around the US and I can get you picture if you need them of how the unit was designed to work.
So either send me pictures of both door or I can send you snap shot of the parts list and pictures to assist you.
I have to ask, if the unit level and were the door removed at anytime prior to the current issue you have?
Thanks
Oct 15, 2013 | Refrigerators
Right door flap not hugging door when ioening left door with right door already open
The doors have to be adjusted. They may have moved out of their intended alignment over time
May 01, 2013 | Frigidaire FGHG2344MF Bottom Freezer...
Woof woof noise from samsung french door refrigerator
it has a technical problem you should call the freeze fixer.
Mar 20, 2013 | Samsung 23.0 cu. ft. Counter-Depth...
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
When i close the left door the right door pops open 1.5 inches this problem has just started i have had the unit for 4.5 years
I had the exact same problem with my Kitchen Aid French door refrigerator...... I had my appliance repair man come twice and we finally found the problem........... the LOWER DOOR HINGE was broken on the inside. you can only tell when you go to remove the hinge from the inside of the door. he replaced it and it works beautifully. I read how many people have had this problem and have replaced the gasket on the door but it didn't solve the problem. that's because it's not the gasket it's the lower hinge in the actual door. good luck
Jan 21, 2011 | KitchenAid Architect KBFA25ERSS Stainless...
Our French doors aren't shutting right. You have to close the left one first, and then the right one. Even if you don't need to open the right one. It didn't used to do this.
It appears that your door hinges are loose. Open each door, take a close look at hinges at the top and bottom. You may be able to see an outline of where the hinge was and needs to be. Raise / Lower Door by hand until hinge is back in place, and tighten with a screwdriver. Pretty common.
Jun 11, 2010 | Samsung RFG237AABP (226 cu ft) Bottom...
Refrigerator Door not staying closed
Try to raise by adjust the 2 front footing slightly higher than the back, this will tilt the unit slightly backwards. That will help the door to close back by itself.
Feb 24, 2009 | LG LRFC25750 Refrigerator French Door
Right side french door does not stay closed
I had the same problem - had my local appliance repair shop come by - simple releveling of the unit such that it is tilted slightly back re-establishes things so that the doors will cloe and pull themselves closed. The gaskets are actually magnetized. If the leveling is correct - even upon closing the left door - forcing enough pressure to push open slightly the right side - it will draw itself back in.
Nov 21, 2008 | Jenn-Air JFC2089HE French Door...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
