Question about Philips 20DV6942 20 in. TV/DVD Combo
DVD not working
Can u help please?
THe dvd unit takes the dvd disk but after a while it says "No disk".
It turns a while stops. A click is heard. Turns again a click is heard and then stops and says no disk.
  • 22 Answers
You would have to open up the unit. Likely the "clicking" is it recentering the head attempting to read the disk.
Most likely you simply have a dirty lens (how old is the unit and how much use does it see?) which could be cleaned gently with a cotton swab and rubbing alcohol.
Posted on Nov 20, 2007
Dvd player in patriot turns off
If the DVD player is mounted in the dash, this is due to an interlock to avoid distracted drivers. If you tried to disable it, the unit will not work at all.
If this is a back-seat only unit, please add a comment with more information on the DVD player.
I hope this helps.
Apr 05, 2013 | Jeep Cars & Trucks
Please Help :S
try clean the lens using only cotton buds no pressure just smoothly wipe, if it would turn ok then great... but still disame, try put vcd cd/ or cd audio only if one click it reads... then the lens has over heated or partially burn, need to replaced.
Dec 31, 2009 | Insignia IS-PDVD10 Portable DVD Player
Dvd not taking any disks
I did not get my problem solve do you have a remedy to solve my problem
Aug 15, 2009 | Samsung DVD-R130 DVD Recorder
The system or DVD recorder turns off itself
It could be because your unit is overheating. Shutting itself off is your player's way of protecting itself. Causes can be form anything to direct exposure to sunlight, Something heavy is on top of the player, to disk speed being to fast.
Mar 31, 2009 | GoVideo Go Video DVD/VCR Combo
Can't record DVD+RW and DVD+ Disks...PLUS
Firstly, you need to finalize the -R disk recorded by and in your unit before it will play back anywhere else.
Secondly, the DMR-ES10 does not support +RW, only -RW.
Finally, I have never heard of a +D. Do you mean +R? It is likely that you have a corrupt disk; change it.
Mar 11, 2009 | Panasonic DMR-ES10 DVD Recorder
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Cyberhome Ch- DVD 300
Your advice was very helpful. After two+ months of tooling around and navigating around the menu blind I was on the brink of trashing it.
At first I tried the stop button with a dvd in the player with no success. After taking the dvd out, turning in off/on then pressing the stop button for 20 seconds the screen turned blue as said.
This help saved me a great amount of fustation.
Thank You!
May 27, 2008 | Cyberhome CH-DVD 300 DVD Player
When i try to open my disk tray it says locked
I had same problem with JVC player. Found out from manual that there is child lock- activated by pressing stop + eject when unit in stand-by mode. (which I must have done accidentally) Unlocked by repeating action - in stand by mode.
May 24, 2008 | Televison & Video
DVD-R130 Says "Disk is unreadable"
I rang samsung and they are swapping it for a DVDr155
Oct 07, 2007 | Samsung DVD-R130 DVD Recorder
Philips 20DV6942 20 in. TV/DVD Combo Logo
42 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
