Question about BargainCell Kitchen Appliances - Others
Easiest way to locate
Find the self installing pins
  • 201 Answers
Right inward
Posted on Jul 23, 2009
Where is thermostat located on a 93 ford escort 1.9 engine
the easiest way to find your thermostat is to
1.) locate you upper radiator hose (pretty self explanatory)
2.) follow this hose to where it enters the engine (the neck the hose is attached to on the engine is you thermostat housing)
3.) remove thermostat housing and replace thermostat ( NOTE: you WILL need a new gasket)
Sep 04, 2011 | Ford Escort Cars & Trucks
I need the wiring colour coding for the rear lights of a 2000 v40d as im fitting towbar electrics
Your post:
Hi There.
here are the 7 cable locations and pin numbers.
Pin 1 Yellow L/H Direction Indicator
Pin 2 Blue Rear Fog Lamps
Pin 3 White Earth Return
Pin 4 Green R/H Direction Indicator
Pin 5 Brown R/H Tail & No, Plate Light
Pin 6 Red Stop Lamps
Pin 7 Black L/H Tail & No, Plate Lights
I found the easiest way to locate the correct wires in the loom is to turn on the lights required and use a circuit tester and splice into the main loom where you have enough wire to play with. Try not to cut the loom as it only causes more problems with bad connections and joins.
Good Luck
Apr 07, 2011 | 2000 Volvo V40
Towbar electrics 7 cables,which goes where
Hi There.
Good Luck
Mar 22, 2011 | 2000 Ford Escort
Gerror 913 en lso archivos201 segenera por tener archivos desatualizado
Obten los controladores de Windows o MAc y actualiza tu printer.Si continua el problema escribeme.
Windows Operating Systems spacer.gif [+] Generic 9-Pin Printer Driver v1.0bEs
Windows 98, Windows 95, Windows NT 4.0, Windows NT 3.51
epson10753.exe - 559KB - posted on 05/29/03
[-] Generic 9-Pin Printer Driver v1.0bEs
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 95, 98, NT 3.51 and NT 4.0 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Microsoft Windows CD-ROM available as the printer driver may require some OS files from the CD-ROM to complete the installation.
downloads_icon.gif Download Now
Windows 3.1
ep10759.exe - 527.2KB - posted on 05/29/03
Windows 3.1
This self-extracting file contains the Generic 9-Pin Printer Driver for Windows 3.1 (Printer Driver v1.0bEs, Core Driver Disk v1.0). This file is for use with all Epson 9-Pin Dot Matrix Printers.
Note: Please have your Windows 3.1 installation disks available as the printer driver requires the "unidrv.dll" file to complete the installation.
Macintosh Operating Systems spacer.gif [+] Network Printer Driver v2.0A
Mac System 7
EPRINT2N.SEA.hqx - 779.1KB - posted on 06/12/96
[-] Network Printer Driver v2.0A
Mac System 7
This self-extracting file contains the EPSON Print! 2 Network Printer Driver files for the 9-pin ESC P2, 24-pin ESC P2, and the DFX printers.
[+] Printer Driver (Serial) v2.0A
Mac System 7
EPRINT2S.SEA.hqx - 610.1KB - posted on 06/12/96
[-] Printer Driver (Serial) v2.0A
Mac System 7
This self-extracting file contains the Epson Print! 2 Printer Driver for serial connections with 9-pin ESC/P2, 24-pin ESC/P2, and the DFX printers.
Dec 17, 2010 | Epson FX 1170 Matrix Printer
Parking brake cable stretched beyond adjustment how do you replace
Rear Brake Shoes- You'll need to know how to remove the rear brake shoes to remove the parking brake cable. REMOVAL AND INSTALLATION Amigo and Rodeo
  1. Raise and safely support the vehicle.
  2. Remove the rear wheels.
  3. Remove the brake drums.
  4. Remove the brake return springs.
  5. Remove the leading shoe holding pin and spring, and then the leading shoe.
  6. Remove the self-adjuster and the adjuster lever.
  7. Remove the trailing shoe holding pin and spring.
  8. Disconnect the parking brake cable from the trailing shoe and remove the trailing shoe. Remove the parking brake lever from the trailing shoe. To install:
  9. Attach the parking brake lever to the trailing shoe.
  10. Connect the parking brake cable to the parking brake lever.
  11. Apply a thin coat of high temperature grease to the shoe contact points on the brake backing plate (locations A and C in the accompanying illustration), piston contact surface (B), and self-adjuster (D). Fig. 1: Exploded view of the rear drum brakes — Amigo and Rodeo 93026g56.gif
  12. Position the trailing shoe on the backing plate and install the hold-down pin, spring, and retainer. Don't stretch the return spring when fitting the shoes onto the backing plate.
  13. Connect the upper return spring and the leading shoe to the trailing shoe and position the leading brake shoe on the backing plate.
  14. Install the adjuster assembly and the hold-down pin, spring, and retainer.
  15. Use a brake spring tool to install the lower return spring.
  16. Install the self-adjuster lever and adjuster spring.
  17. Adjust the shoe-to-drum clearance to 0.0098–0.0157 in. (0.25–0.40mm) and install the brake drum.
  18. Check the brake drum for scoring or other wear. Machine or replace as necessary. Check the maximum brake drum diameter specification when machining.
  19. Install the rear wheels. Lower the vehicle.
  20. Road-test the vehicle.
Aug 17, 2010 | 1997 Isuzu Rodeo
Have plug in towbar electrics for 52plate passet saloon need diagram to wire plug at towball
Hi There.
Good Luck
Jun 02, 2010 | 2002 Volkswagen Passat
WIRING DIAGRAM FOR TOWBAR ELECTRICS WOULD EXPECT TO BE COMMON BUT MODEL IS A 1994 MITSUBISHI PAJERO
Hi There.
Good Luck
May 03, 2010 | 1988 Mitsubishi Pickup
Fitting single towbar electrics, Hyundai Coupe 2.0 2004 (Tiburon)
Hi There. Im not sure where you are but this is the sequence for the UK< Hope it helps.
I found the easiest way to locate the correct wires in the loom is to turn on the lights required and use a circuit tester and splice into the main loom where you have enough wire to play with. Try not to cut the loom as it only causes more problems with bad connections and joins.(
Good Luck
Apr 16, 2010 | 2003 Hyundai Tiburon
Your a big help so far and I see a coin looking super thin but soldered I think. What remove it and solder it back? Wait several minutes and then reset the password to Bios?
Some BIOS batteries do have wires soldered to them but the easiest way to disconnect is remove the plug from the oBo at the other end of the wires. Saves soldering.
Or you could look for the BIOS jumper pins which should be located near the battery (three Pins) Pin 1&2 will be shorted with a jumper. Move jumper to pins 2&3 for 30 secs and move back. Job done.
Feb 09, 2010 | Office Equipment & Supplies
Pin for driver side door bottom hinge pin seems to have lost the bottom part of the pin, what is the easiest way to replace the pin?
door pins are available at dealer and part store
to change you have to remove the door from truck and change the pins
Jul 09, 2009 | 2002 Chevrolet Blazer
Kitchen Appliances - Others Logo
32 people viewed this question
Top BargainCell Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a BargainCell Kitchen Appliances - Other Expert? Answer questions, earn points and help others
