Question about Black & Decker 14" Grass Hog Xp Trimmer/Edger
Motor spins, shaft does not...
Was using the trimmer to trim grass, feed doesn't work, but that's another issue, anyhow, the motor kept going, but the shaft quit spinning.
  • 32 Answers
Sounds like the cable has broke inside the tube or it popped out of place. loosen the bolt on the motor casing holding the tube and separate the two pieces and pull the cable out. Should be a square at each end of cable.. if not post again
Posted on Jul 23, 2009
Why did my weedeater lost power when trimming on grass but still spun?
There is a cable that runs from the motor to the trimmer head check that. Remove trimmer b.y removing small screw at the base of trimmer head
Aug 05, 2014 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
TB70ss clutch
Check to see if there is any material collected around the base of the head, around the tube that provides the energy to spin. It may cause the power to be diminished a great deal, so that must be cleaned away thoroughly. Check to see if you can spin the head freely by your hand, without the motor being on. If not, it may need lubrication down the indide of the power shaft. A light grease would do that, or even a heavy oil poured down the shaft, but not too much.
Sep 20, 2012 | Troy Bilt Tb70ss Gas Trimmer
The motor is working but the trimmer part stopped spinning. I checked the line but there is plenty, I removed and replaced the line spool but still not working.
Does the trimmer head spin freely? If so then it is somehow disconnected from the motor. There should be a motor coupler somewhere near the motor and also near the trimming head. Make sure they are connected.
Jun 06, 2011 | Black & Decker 14" Grass Hog Xp...
Hi, I have a RYOBI ELT1100QFA electric line
electric line trimmers suffer from one major design problem
the motor has phosphor bronze bushes and the bottom bush goes dry from the grass juice and wears out and the armature poles out and lacks power to work
to get 5 years is good but it is time to take it in for a service or junk it and get a new one
Mar 30, 2017 | Ryobi Garden
I just bought a BD Grass Hog and after 1 h of use,
If the noise was up by the handle it may have been the drive pulley breaking loose of the shaft on the motor causing the motor to spin and stop the flex shaft of the trimmer. Another possibility would be the small belt that aids the flex shaft. If those don't fix the problem check the lock nut that bolts the flex shaft to the spool housing. If the shaft broke free from the housing the motor would still run and the shaft would turn, but the spool housing would not spin if it does it could be stopped very easily. Definately check the warranty.
Jul 07, 2010 | Black & Decker String Trimmer Cordless 12"...
B&D grasshog XP motor squeeled and spin rate slowed. repairable?
I just saw your post. Check the area between the housing and the head, along the shaft. Fibrous debris (in my area, this loosely translates into "lilly leaves") gets wound around the shaft, and will slow the universe down to a crawl. The only way to get it loose is to cut it loose, or unwind it.
Best regards, --W/D--
Aug 18, 2009 | Black & Decker 14" Grass Hog Xp...
We were trimming our grass and the line stopped spinning
flex shaft most likely broken check online or at a local lawn and garden shop the are normally not too much and somewhat easy to replace
Aug 07, 2009 | Black & Decker 14" Grass Hog Xp...
I'm in a similar situation with my GH1000, except that it was a part that comes with whole motor assembly. I could sell you the shaft assembly of my trimmer, or I'll buy your motor assembly. Yes?
Jul 26, 2009 | Black & Decker 14" Grass Hog Xp...
Black & Decker 14" Grass Hog Xp Trimmer/Edger Logo
295 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
