Question about Refrigerators
Side by side won't dispense ice.
I have a 2 year old Kemore Elite side by side. I was getting a glass of crushed ice when it stopped dispensing any ice, cubes or crushed. It makes ice fine but stopped dispensing it. I removed the ice bucket and cleaned it using hot water to melt all the ice in the mechanism so there was nothing binding up but it still doesn't dispense. I can't find my owners manual to check it out so I thought I would try you.
Gary Kassuba
  • gkassuba Jul 23, 2009
    The model number is 106.57799701 the serial # is SU4129334.
    I did as you requested and the motor is not turning so obviously the augar isn't turning eigher. When I push the ice dispensing pad there is a noise for about 1-2 seconds but as I said, the motor isn't turning.I was wondering if there was a reset button for the ice dispensing motor somewhere????
  • Mike Smith
    Mike Smith May 11, 2010
    Need model number to help .
  • Refrigerators Master
  • 4,654 Answers
Take the ice container that has the auger inside it and press the door switch in while you press the dispenser. If the auger motor in the back works empty the ice container and see if there may be frozen ice preventing it from turning. If yes then defrost and dry the container and replace. If this does not solve the problem get me your model number for example 213.256489 for Sears and I will help you track the problem down. Sea Breeze
Posted on Jul 23, 2009
  • 1 more comment
  • John Tripp
    John Tripp Jul 23, 2009
    I see you did that already. Send the model number, Sea Breeze
  • John Tripp
    If you have a voltage meter we need to check the voltage at the wire connections on the auger motor with door light switch in and while pressing the dispense button. Thanks, Sea Breeze
  • John Tripp
    No there is no reset button. The auger motor has 120 volt power supply to the motor going through a pin plug. The auger power is turned off if the freezer door is open. You may need to take the motor out and examine and check the pin plug for this voltage. I am trying to make sure the control panel is not at fault. The noise is where? Does the auger look like it tries to move? 2252130 Auger Motor
    PART NUMBER AND MODEL SEARCH FEATURE
    http://servicepartstec.blogspot.com/
    http://appliancepartseast.blogspot.com/
ICEMAKER FROSTING UP
Try to take some ice from the dispenser. Remove the glass and open the freezer door to look down inside the dispenser chute and see if the trap door has re-closed. If it remains open warm, humid air will enter the ice bucket and gradually freeze the cubes together. Trap door remaining open is generally caused by a rusted electrical coil which pulls the door open electrically then sticks, unable to re-close. Coil is located behind the panel that operates the dispenser. Relatively easily accessible.
Jul 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Only crushed ice comes out of dispenser
your model # is incomplete but here it goes.
1.take your ice container out and run hot water thru it. you want to defrost all of the ice build up inside of it's housing.
2. make sure the long lever under the container moves up & down when you press on it.
3.w/the container removed, you will see a fork like object and next to it amn openning w/a small plastic square part inside. make sure that part moves freely up & down. that solenoid is what gives cubed ice.
let's start there first
Jul 14, 2009 | Whirlpool ED2FHEXN Side by Side...
TFX22CR GE refrigerator TFX22CRXFWW does Not dispense ice.
I had this problem with a similar refrigerator. The problem was the slide switch burns itself especially if you slide it from ice to water while holding the glass in to get ice and water into your glass. Better to slide it to ice, press the glass in to get ice, release the glass to stop the ice, slide the switch to water, then press the glass in again to get water. I "fixed" mine by removing the control panel and soldering some of the connections on the slide switch together so that we now have no crushed ice function, but the ice cubes work again. You can also replace the circuit board in the control panel to restore it to like-new operation. I could not find a place to order just the slide switch.
Not sure if this is the same problem with your unit, but sounds the same.
Dec 06, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Whirlpool Side by Side Refrigerator Wont dispense ice
if you lift out the ice bucket you will see the "gear" that turns the auger. The gear is metal but the part on the bucket is plastic and this can become stripped out. Also check that there is not ice frozen around the bottom of the bucket where an ice cube may have lodged the chute door partially open and melted some of the ice in the bottom creating a blockage.
Nov 06, 2008 | Whirlpool GC5SHEXNS Side by Side...
Ice dispenser not dispensing.
the hex wrench your after is know as nut ddriver screw drivers / you can remove the auger assembly quite easily the activation switch is located in the door assemby. be carefull the auger is powerfull.
Aug 22, 2008 | Whirlpool GS6NBEXR Side by Side...
Ice dispenser not working
Ice auger in freezer compartment not working. Common problem with GE side by sides I know of at least 3
Jan 21, 2008 | Amana ACD2232HR Side by Side Refrigerator
GE Stainless Steel side by side fridge GS425JSRF - 2 ys old
Make sure there is no obstructions from the time the ice leaves the chute until it drops into the glass. make sure the motor that moves ice and out to the area for the cup is stuck or seized up let us know thanks
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
318 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
