Question about Ryobi Garden
How to remove drum connector off ryobi weedeater
How can I get the drum/connector assembly off so I can install a new starter cord, for Ryobi weedeater cs30
  • Anonymous Mar 19, 2014
    runs and shuts off
    Scholar:
  • 71 Answers
I believe there are four phillips headed bolts around the outside edge of the housing
Posted on Jul 23, 2009
I have a weed eater that has no fuel line. Does anybody have instructions on where to connect the fuel line? The model is Rybio 31cc, model #725r.
Posted on Apr 24, 2013
Ryobi string trimmer RY34420 has a non retracting pull cord. How do I fix it?
The starter assembly is between the motor and boom so you have to remove the boom from the motor housing. Usually one nut & bolt at the nose of the starter housing. There may be another lock bolt. You shouldn't have to remove the throttle cable and leads but it depends on how tight the factory installed them. Remove the starter housing. If you're real lucky all you have to do is pull some starter rope up past the pulley and wind the pulley in the direction the rope pulls back into the housing. You have to pull the rope around the pulley as you wind it. If the spring catches and builds tension you're good, wind it four or five times or enough to fully pull the rope back in. If the spring doesn't catch or releases every two or three turns it has to be replaced. You may have to replace the spring and container (PN638033001) and/or the easy start assembly (PN310022001).
Aug 31, 2010 | Ryobi Garden
Ryobi trimmer plus won't start. No sound at all
if it pulls super easy and it doesnt sound like the engine is even rotating when you pull it it is your pull cord assembly . basically its a giant ratchet my advise is just get a used one of a blown up weedeater it would be cheaper
May 12, 2010 | Garden
I have a Ryobi RLT30CESN. The started cord broke
Dont remove the center screw out of the spring pully or the spring will fly out. you put in the cord while the spring is assembled inside. Take the housing off but do not remove the pulley unless the spring is broken. The string can be put in using needle nose pliers from the inside of the housing once it has been removed. once installed you wind the cord around the pully and then turn pulley untill you get proper spring tension. Once tension is achieved you fish the cord back threw the eyelet coming out of the housing and tie the handle to the cord. It is a really simple and easy thing to do but hard to put into words.
Nov 22, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 40cc chain saw, pull cord won't turn rotar assembly
I had the same problem with my 18 inch Ryobi saw. The problem is the tabs that engage the recoil to the flywheel are of poor quality steel and they bend out of position. The end result is when you pull tyhe rope it just jumps and wont start. Eaven the new parts do the same thing. Simple soultion is remove the recoil starter four screws require a torx bit or a flat screwdriver. after your remove the recoil starter using a pair of pliers bend the two tabs upwards untill they are not quite straight up (about a 80 degree angle be carefull not ot brake the tab off) once you have done this remove the center nut that holds the flywheel on. the silver pins that hold the tabs in position need to be punched out but remember how they go back by doing only one at a time and remember how the spring is installed. Turn the flywheel over and using a punch and hammer remove the pins. Put the tabs in a vise to hold them sucerly clean the steel as best you can on the inside of the bend. Fill the bend with brazing rod or coat hanger if you haven't got any brazing rod avilable. You don't have to com;leatly fill the bend but put enough in there to suport the tabas so they can't bend agin. Reassemble the saw and you're done. Mine works great now, better than new. This problem isn't limited to recon saws only, mine is a new saw and I still had the problem. Good luck herbdogs
Aug 14, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi 40cc chain saw, pull cord won't turn engine
If it has ball bearings in the rachet mechanism they may be sticking and need cleaning so they move freely.!
Replacing pull cord on weedeater
there is another t20 screw in the neck of the drum. once removed you will expose the drive clutch. soak it good with WD40 then unscrew it from the shaft. if you have all the housing screws out, you should be able to simply remove the housing to expose the pull cord assembly, screwed to housing.
Aug 06, 2009 | Ryobi Garden
Garden Logo
958 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
