Question about Dishwashers
Need a dishwasher with less than 34 inch height clearance any suggestions?
  • 36 Answers
Asko
Posted on Jul 24, 2009
Which dishwashers are less than 830mm high, to fit under my work surface?
Peter,
830mm equals 32.68 inches. You will just have to look at the specs of any dishwasher that you are interested in and see if they will fit in less than that height. Most dishwashers that I have installed would fit between 32 and 34 inches in height. Hope this helps!
May 15, 2015 | Dishwashers
Avanti calls for a cabinet height of 34 1/2". However, the dishwasher is only 32 1/4" tall. What do you do to fill the gap of 2 inches at the top?
you don't fill the gap. There needs to be some clearance for the door to be able to swing open without contacting the underside of the counters. You can always decrease the gap a little by using the adjustable stands on the bottom of the unit. The unit will come with a kickplate that can adjust to multiple heights.
Apr 27, 2015 | Avanti Dishwashers
I have a Minerva 44" Fan. I have Vaulted Ceilings with a 12-12 pitch. The down rod is 3/4 in. What slope ceiling adapter is recommended ?
Mike, a 12/12 pitch is 45 degrees. You may have to use a little math to figure out how far down to hang the 44" fan to keep from hitting the angle of the ceiling. Geometry specifically. Remember the A sq + B sq = C sq for figuring the hypoteneuse of a right triangle?? If the ceiling fan is 44", the base (A) of the right triangle is 22" with NO CLEARANCE to the angled ceiling. A 45 degree angle dictates the base and the height are equal, so height (B) of the triangle is also 22" with NO CLEARANCE. If you want a few inches of clearance, extend the height by 4" and there should be enough clearance to allow the fan operation.
I would suggest playing with the figures before you buy the extension rods though. The simple answer to you question remains however...45 degrees.
Mar 08, 2015 | Dryers
What are the demensions of my GE dishwasher Model# GSD2800D03?
Approximate Shipping Weight 100 lb Net Weight (lbs.) 90 lb Overall Height 34 in Height w/Legs Extended (in.) 35 Overall Depth 25 3/4 in Overall Width 24 in
Jul 23, 2011 | Maytag Dishwasher
What are the product dimensions
Hi and welcome to FixYa, I am Kelly. The installation guide with the dimensions can be found here:
http://www.managemylife.com/mmh/installation_guides/3932/KENMORE-Dishwasher-L0504234?brand_name_search=665.15952 (7.87 mb file)
The top of the cut out is 33 & 7/8" Min. to 34 & 7/8" Max (adjustable legs for height)
Minimum space to counter top parent material 1/4" (Top of dishwasher cabinet is screwed in at the top)
Depth 24 & 1/4 inch minimum
Width 24 & 1/4 inch minimum (Allows for 1/8" clearance on both sides)
Thanks for choosing FixYa,
Kelly
Feb 22, 2011 | Kenmore 15952 Dishwasher
I need the depth of the dishwasher I have the height at 34 1/2 and width at 23 7/8 Maytag MDBH969AWW
This may be too late for your needs, but, the assembled depth is 26 inches. 49.5 inches with the door open.
Jun 20, 2010 | Whirlpool MDBH969AWB Builtin Dishwasher
Dimensions
This model is a 25.6 Cu. Ft.
Height to Top of Hinge: 69 1/4"
Height to Top of Case: 68 3/4"
Case Depth w/o Door: 28"
Case Depth less Door Handle: 32 1/4"
Case Depth w/ Door Handle: 34 7/8"
Depth w/ Fresh Food Door Open 90°: 50 1/16"
Width: 35 3/4"
Width w/ Door Open 90° w/ Door Handle: 42 3/8"
Air Clearances - Each Side: 1/8"
Air Clearances - Top: 1"
Air Clearances - Back: 1"
Approximate Shipping Weight: 360 lbs.
Capacity
Total: 25.6 cu. ft.
Fresh Food: 16.02 cu. ft.
Freezer: 9.59 cu. ft.
Shelf Area: 22.4 sq. ft.
Dec 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
What the height of the kenmore model # 13743
all dishwasher that are standard . and this one is .. 24 in wide x 34 in h x 24 d. 34 1/4 is what the spec ask for .. hope this helps mm
Dec 07, 2009 | Kenmore 13743 Staimless Steel Built-in...
Height for dishwasher is only 33.5 inches
we found a fridgidare dishwasher the had a range of 32.5-34 model number FDB2410HIC1 try it, it saved us from having to do alot of tile cutting
Jan 05, 2009 | Dishwashers
Replacing an old diswasher
all dws are standard hight
Dec 24, 2008 | GE Dishwashers
Dishwashers Logo
1,525 people viewed this question
Top Dishwashers Experts
Owen Barnes
