Question about Kitchen Ranges
I just cleaned my Maytag self cleaning oven, and now I can't get the door unlocked!!! Help!!!
    President:
  • 1,124 Answers
There is usually a unforgiving timer on those. Just have to wait..
Posted on Jul 22, 2009
Oven door is locked with food in it how to unlock asap
Hi , Anon !
My name is Ashlynn .
If your oven is locked , here's some ways you can unlock it :
  • 1 Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
  • 2 Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • 3 Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • 4 Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    But it seems you have food inside so ,
    Press cancel on the cooking cycle , and let it cool to room temperature , and then try to open your oven .
  • Feb 25, 2015 | Maytag Ovens
    Admiral electric range with self cleaning oven
    Hey there gcato1, your problem is actually a protective feature designed to prevent you from getting burned. The self cleaning feature runs at extremely hot temps. Until the temperature reaches a safe level, the oven door will remain latched. Be patient and the problem will solve itself.
    Jan 29, 2008 | Maytag Admiral LER3330AAW / LER3330AAZ /...
    Door won't open after self cleaning and cool down has stopped.
    if you are sure it has cooled down cycle it again to clean hitting the cancel button shorty after it starts
    Dec 09, 2011 | Maytag CWE5800A Electric Double Oven
    Cannot unlock oven door
  • Here it is!
  • Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
  • Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
  • Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
    Nov 10, 2011 | Maytag Ovens
    I have a maytag gemini double oven and the bottom oven door will not open
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    Self Cleaning Oven Problem
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
    Dec 19, 2009 | Maytag MEW6630D Electric Double Oven
    Maytag gas oven after self-clean cycle door locked "dr" on displa
    unplug it and let it stand for a few minutes
    let the e- prom clear
    plug it back in, should unlock
    if it does not you need a new sensor
    Sep 27, 2009 | Maytag MGS5770 Gas Kitchen Range
    Can't Unlock oven doors after "self-Clean" maytag double oven
    I was advised to disconnect power for at least 60 seconds to clear the control board. I did this several times with no luck getting the door unlocked. However, a few hours later, the door did finally unlock. Not sure what ultimately caused the door to unlock, but happy that I did not have to replace the control board.
    Dec 22, 2008 | Maytag Kitchen Ranges
    Self-cleaning oven will not start.
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
    sad
    Dec 11, 2008 | Maytag MER6772 Gemini Electric Kitchen...
    How does self clean work
    MOST SELF-CLEAN OVENS RAISE THE TEMPERATURE IN THE OVEN TO ABOUT 850 DEGREES AND BURN EVERYTHING TO A POWDER. THAT IS WHY THERE IS A SPECIAL DOOR GASKET AND IMPROVED INSULATION AROUND THE OVEN LINER. THE AVERAGE CLEAN CYCLE
    TAKES 3 HOURS TO COMPLETE. YOU SHOULD BE ABLE TO
    LOCK THE OVEN DOOR (SOME MODELS LOCK THE DOOR
    AUTOMATICALLY) SELECT SELF-CLEAN, AND START.
    OLDER MODELS WITH A MECHANICAL TIMER AND CLOCK REQUIRE SETTING THE START AND STOP TIME.
    Aug 01, 2008 | Maytag Kitchen Ranges
    How to user self cleanning feature for oven
    my oven is on f 9 cant turn off and get oven door to unlock
    Feb 17, 2008 | Maytag CWG3100A Gas Single Oven
    Kitchen Ranges Logo
    78 people viewed this question
    Top Kitchen Ranges Experts
    Oloyede Monsuru
    Paul Carew
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
