Question about Refrigerators
INSTALATION OF MAYTAG DEFROSTER TIMER
How do I replace the defroster timer in a maytag fridge model MTB2656GE
    President:
  • 1,136 Answers
Hi, Here is a picture of the control panel where the timer is located. There is a1/4" screw holding the control panel up. Remove the screw and the control panel should release. The timer has a wire harness of 4 wires. It can only plug in 1 way.
Please let me know if this has helpes you at all or if I can assist you further.
Thanks
Vic
Posted on Jul 26, 2009
Maytag gs2625geks
There is a defrost timer that may be going bad.
Jan 28, 2014 | Refrigerators
Not defrosting. I replaced the defroster timer circuitry and heater element last April. It worked for 3 months or so and started freezing again.
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 29, 2010 | Maytag MSD2756G Side by Side Refrigerator
MY MAYTAG MODEL MSD2734GE STOP COOLING ON BOTH SIDES...HEELLLPPPP
Your timer is stuck that controls the defroster. Replace it and everything will be fine.
Oct 16, 2009 | Maytag MSD2756G Side by Side Refrigerator
Frig Freezing Up/Frig side warming up Maytag MSD2454GRW
I think your voltage is fine I just believe the defrost timer is worn out and not cycling properly resulting in less defrost and higher refrigerator temperatures. Thanks, sea Breeze
Aug 26, 2009 | Maytag MSD2454G Side by Side Refrigerator
Maytag refrigerator, feezer side coil frozen and frigirator not
Defrost circuit failed, needs to be able to defrost the coils so air can pass through them thus cooling evenly. You can check the heaters located on the coils probably near the bottom back wall of the freezer with a ohm meter if you read through, the heaters are good, if you get no reading the heaters are bad. Or could be defrost timer or on newer models the adaptive defrost control which is a circuit board. If its an older model you can manually turn the timer with a screwdriver if you feel resistance, then you should replace the timer. Also in the circuit is the defrost thermostat located on the coils, this is the least expensive of the 3 components to replace. You should have a schematic located under the fridge, use this to determine which type of timer you have and for further trouble-shooting. Please let me know if this helps
Aug 22, 2009 | Maytag MCD2257HE Side by Side Refrigerator
Defrost Timer?
depending on model thats either your timer or cold control would be about 200
Mar 19, 2009 | Maytag MBB2256GES Bottom Freezer...
Maytag fridge defrost timer location
If this unit has the temp controls in the middle top of the fridge then it is in there.
Dec 24, 2008 | Maytag MSD2456G Side by Side Refrigerator
My american style fridge/freezer is continually running but not keep cold. Have to empty the freezer side and the fridge is not cold either
It could be the defroster doesn't work. Frost buildup has blocked the flow of cold air.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Nov 22, 2008 | Maytag Refrigerators
Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
Nov 18, 2008 | Maytag Refrigerators
Refrigerators Logo
339 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
