Question about Maytag Dryers
I cannot figure out how the top clips go back on the front of the dryer
  • rmattice Jul 23, 2009
    The top fastening clips came off when I took the front off to replace the thermostats and I cannot figure out how they go back onto the dryer.
    Brigadier General:
  • 8,619 Answers
Hi
If you are asking about Maytag Dryer then check this link. Also please explain what exactly you are looking for so that I can assist you further.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 23, 2009
  • Rylee Smith
    Rylee Smith Jul 23, 2009
    Hi
    Please check this link, its a kind of service manual for your Maytag dryer which will help you resolve your issue.
    Dryer Service
    Thanks
    Rylee
The belt attached to the blower wheel on my Whirlpool Cabrio dryer has come off. How do I reattach it?
Unplug the power cord of the Whirlpool dryer from the electrical outlet before installing a new belt. Remove the lint filter from underneath the lint filter cover. 2 Unfasten the screws underneath the lint filter cover with a screwdriver, setting the screws in a safe place. Slide a putty knife between the dryer top and the cabinet near the front, lifting up on the knife to detach the top from the plastic clips on the cabinet.3 Flip the dryer top back against the wall so it is resting on the rear hinges. Locate the screws on the inside of the upper front panel near the top.4 Unfasten the screws on the inside of the upper front panel with a screwdriver. Lift the panel up off the metal clips on the front of the dryer cabinet. 5 Unplug the door switch connector from the back of the upper front panel by hand, setting the panel out of the way. Slide the putty knife between the lower front panel and the dryer cabinet, pulling the knife away from the cabinet to detach the panel from the plastic clips on the cabinet.6 Place a couple of wood blocks under the lip of the dryer drum to hold it in place. Locate the idler arm near the motor at the base of the dryer.7 Move the idler arm forward to relieve the tension on the belt. Take the belt off the motor and idler arm pulleys, lifting the drum up and sliding the belt off the drum.8 Install a new belt around the dryer drum, looping it over the idler arm and around the motor pulley. Move the idler arm back into position to add tension to the new belt.9 Remove the wood blocks from underneath the lip of the dryer drum. Plug the door switch connector into the back of the upper front panel by hand.10 Slide the upper front panel over the metal clips on the front of the dryer cabinet, securing the top of the panel with screws. Fasten the lower front panel to the front of the dryer cabinet, pressing the panel onto the plastic clips by hand.11 Flip the dryer top back down onto the top of the cabinet, pressing down to secure the top to the plastic clips on the cabinet. Fasten the screws underneath the lint filter cover with a screwdriver.12 Slide the lint filter back under the lint filter cover by hand. Plug the power cord of the Whirlpool dryer into the electrical outlet.
  • Oct 11, 2011 | Whirlpool Dryers
    How do i get to the inside of the dryer - i need to replace a part in the front and can't figure out how to get the front panel off
    Hello- First, BE SURE the dryer is unplugged, and then be sure again. You will need to release the two retaining clips that attach the top the the front. They are located under the front of the lid a couple inches in from each side. The best tool is a putty knife or something a flat paint scraper. Place the tool between the top of the front panel and the lid and pry up a little bit in order to see the clips, they are about an inch wide. You have to press hard right into in (its like a flat metal spring) and pry up at the same time and the lid should release. Repeat on the other side. They can be a bit tricky but just don't force it too much. Once the clips are released the top hinges towards the back. There should be a wiring harness that goes to the timer and switches and one that goes to the door switch, these have plastic connectors that should separate them as a unit. There is one screw on each edge of the interior of the front panel that holds it to the main dryer cabinet, take these out and pull the front panel forward and up and the panel should separate itself from the cabinet. You have to be careful when you put the front panel back on that it slides in on the bottom retainer clips and that the top of the drum is positioned correctly over the felt on the front panel. Just don't force anything. Hope this helps, best regards.
    Sep 27, 2010 | Frigidaire FGQ332ES Gas Dryer
    How do you get the bottom panel under the door of the dryer off? It looks like there are clips of some sort there, but can't remove or move the clips enough to remove the door? please give step by step...
    Unplug the dryer before attempting any repair works.
    The bottom front panel is secured to bottom of the top front panel by two securing clips. Insert a flat-bladed screwdriver between the top front panel and the bottom front panel as shown then pry the panel out then lift it off the cabinet.
    Install the bottom of the bottom front panel first when reinstalling then push the top back into position until the clips engage.
    Aug 21, 2010 | Kenmore 62982 Electric Dryer
    Any advice or tricks to removing the top of my Kenmore Dryer for belt installation? I've already removed the control console. there seems to be some sort of clip I need to figure out. Kenmore...
    on front side of cabinet between top and front, in that seam about 2 inches in from each side is a clip.  i use a paint scraper to wedge in there on each one and it will pop open for you.
    Jul 30, 2010 | Kenmore Dryers
    Whirlpool LGC5000PQ0 I've taken off the back and found that I can't access the part there. There are no bolts on the front panel. I was able to lift the top a bit and noticed that there are bolts holding...
    most old dryers have a funny clip in the front.....with a putty knife there r 2 flat clips in the front close to either end of the machine, if you get that popped then the top will open up,,,, or if you take off the back to where the controls r you'll see a couple of bolts then if you lift an pull to the back of the machine it will come off..then you'll see what you goota do... hope that helps...
    Jan 15, 2010 | Whirlpool LGB6300 Gas Dryer
    How do I replace a dryer belt on Kenmore dryer
    You have to practically completely disassemble the dryer and remove the drum. If you can't figure it out, you should call an expert. Sometimes getting it apart isn't bad, it's putting it all back together that gets you. ;-)
    Dec 27, 2009 | Kenmore Dryers
    Dryer turs but it will not heat. how do i take off the front panel. ge model # dvl223gyoww
    you have two clips on the part where the top and front panel meet the clips are about 2 to 3 inches away from each side  just pry those with something like wire cutters (what i like to use) once you pry it open both clips the front panel than is only held by two hook like objects on the bottom which you just have to unhook it by pulling up with the front face  you'll figure it out once you get the first two clips off
    good luck
    Jun 07, 2009 | Dryers
    I have a Maytag Neptune dryer that has one of the agitators? that have come loose and am trying to figure out how to get to it to tighten it back up. It's an MDE5500AYW. Thanks
    THE FRONT OF THE DRYER IS REMOVED BY OPENING THE DOOR AND REMOVING THE TWO SCREWS HOLDING THE HINGES TO THE FRONT PANEL. ALSO, REMOVE THE TWO SCREWS ON THE OPPOSITE SIDE OF THE OPENING. PULL THE FRONT PANEL TOWARD YOU AT THE TOP. IT WILL BE HINGED AT THE BOTTOM. ONCE YOU HAVE IT TILTED TOWARD YOU, PICK IT UP OFF THE BOTTOM HINGES.
    THERE ARE TWO RETAINING CLIPS HOLDING THE TOP DOWN AT THE FRONT CORNERS. THESE CLIPS ARE HELD ON BY A 5/16TH HEX HEAD SCREW. REMOVE THE SCREW AND CLIP AND YOU CAN LIFT THE TOP. IT IS HINGED AT THE BACK AND YOU CAN RAISE IT UP AND BACK OUT OF THE WAY. YOUY NOW HAVE ACCESS TO THE OUTER SIDE OF THE DRUM. ROTATE EACH OF THE BAFFLES TO THE TOP AND TIGHTEN EACH SCREW AS THEY COME TO THE TOP.
    Apr 22, 2008 | Dryers
    Mde9306aya How do I take the front off
    open the top and look inside on the left and right sides of the front panel some maytags have two screws on the front panel just below the door where the hump is if thats your mod take those out and pull the panel out at the bottom then down as there are two spring clips at the top if thats not your mod then take a putty knife facing the drier come from the edge about two inches then depress the spring clips one at a time and lift the top but i think blower wheel is under the back panel
    Dec 29, 2007 | Maytag Neptune MDE5500AY Electric Dryer
    Amana gas dryer
    You have to take the front off on that model.. to get at the inside.. heres a diagram that may help ya out http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=1268&modelDesc=AMANA%20LAUNDRY&modelNumber=ALE331RAW&documentID=M0411885&documentTypeID=PLDM&documentClassCode=PV&titleType=DOOR%2C%20FRONT%2C%20ACCESS%20AND%20TOP%20PANELS&titleID=00002&
    Oct 10, 2007 | Amana ALE331RAW Gas Dryer
    Dryers Logo
    23 people viewed this question
    Top Maytag Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
