Question about Tablets & eReaders
Not used Kindle for long time.Battery showing very low image. Been on charge for 4 hours and has not moved
    Top Expert:
  • Tablets & eR... Master
  • 47,659 Answers
Needs a new battery computer repair shops usually can assist you
Posted on Feb 20, 2017
    New Friend:
- - - - - Choi Minzi - - - - -
Look What You Made Me Do lyrics
Posted on Oct 14, 2017
    New Friend:
  • 3 Answers
Very helpful. I'm just starting out and it's cool to super mario world know there are some people out there who madalin stunt cars 2 dedicate time to giving such slope helpful tips.
Posted on Apr 19, 2017
Screen does not show a status bar any longer. how to I recover it?
Amazon.com Kindle Help Forum
www.amazon.com/gp/help/.../kindleqna?ie...
Amazon.com, Inc.If you have a newer Fire you swipe down from the top of the home screen to open it. ...I can't get the settings bar to show up, because swiping doesn't work. .... Does anyone out there have any ideas on this problem? .... have erased ALL of them) still no status bars/times/access to anything. oh and mine is the kindle fire hd.
About Charging Your Kindle Fire - Amazon.com
www.amazon.com/gp/help/.../display.html?ie=UTF8...
Amazon.com, Inc.Kindle Fire 2nd Generation: Fully charges in 3.3 hours; Kindle Fire HD 7": Fully ... The battery indicator at the top of your screen should also have a lightning ... You can showthe percentage of the battery charge in the Status Bar at the ... Your Kindle Fire will not charge as efficiently when connected to a computer and in use.
Navigating Your Kindle Fire HD 8.9 - Amazon.com
Dec 25, 2015 | Amazon Kindle Fire HD
How do I fix a Kindle Fire whose battery runs low too often.
The only real ways are to 1)Install Android and keep it connected to the charging USB cable. You lose the original Amazon OS and the free Amazon Prime movies. or 2)Install a new battery, There are YouTube videos showing you how. I chose method ! and I'm having fun learning Android KitKat 4.4.2
Apr 12, 2015 | Amazon Kindle Fire HD
My kindlefire fire is not staying on it will show the kindlefire logo but turn right back off I have a brand new charger and wire but still no luck
Did you turn the Kindle Fire on immediately after inserting the charger?
The battery may be so low that it will not operate until after it has charged for more than 24 hours.
If that is the case, it is also possible that the battery life has been permanently compromised and won't last long even if you finally get it to work.
It is also possible that the charging port on the bottom edge of the Kindle Fire has been damaged...possibly from forcibly inserting a charging cable upside down. If the port is damaged, the cable would not make contact properly and would not charge.
Mar 15, 2015 | Amazon Kindle Fire HD
How long to charge kindle fire hdx when new
It should take under 6 hours for a full charge.
Feb 19, 2015 | Amazon Kindle Fire HD
My kindle of two years old battery will only charge to half full, is that normal and can I replace the battery
Lithium ION batteries are usually rechargeable. The use mode for these batteries is that there are a set number of recharges that equate to the life of the battery. Usually that life is approximately 1,000 charges.
If you use your battery to 50% then recharge, you can do this ~2,000 times. As the life of the battery is used up, the maximum charge lessens which means where you may have had 8 hours of play time when the battery was new, you will only have 6 hours as the battery life is used up.
In order for a Lithium ION battery to recharge there must be at least a small amount of charge left as a "seed" for that recharge. If you drain a L-ION battery down to zero, it may never recharge again or the max charge will be reduced to an insignificant amount of the original full charge. eg instead of 8 hours you may only get 15 minutes, or 5 minutes, or no minutes.
You are much better off recharging when 50% depleted than using it up til your product stops.
L-ION batteries cannot be repaired only replaced. Most cheap products using L-ION batteries cannot have their batteries replaced.
Places like Batteries + are able to replace some tablet batteries.
Jan 20, 2015 | Amazon Kindle Fire HD
My kindle will not turn off
Did you try
Instructions
  1. Frozen Screen or Unresponsive Kindle
    • 1 Unplug the Kindle.
    • 2 Move the power button to the right and release. You should see a green LED light for two seconds.
    • 3 Move the power button to the right and hold for five seconds. The green light should blink three times and then the screen will go blank. Release the power button after it does.
    • 4 Turn the device back on by sliding the power button to the right and releasing it.
    Perform a Hard Reset
    • 5 Perform a hard reset if the previous steps are unsuccessful or if the Kindle screen is showing lines.
    • 6 Slide the power button to the right.
    • 7 Hold for 15 seconds.
    • 8 Recharge the battery if the device continues to be unresponsive.
    • 9 Restart the Kindle after charging.
Read more : http://www.ehow.com/how_7655306_reset-kindle-3g.html
Jul 29, 2014 | Amazon Kindle 3G
Kindle keeps turning itself off
This is usually a sign of either a failing charger or Kindle, let's try to hard reset the Kindle.
Step 1: Press and hold the power button for 60 seconds
Step 2: Plug the Kindle into the changer, press and hold the power for 30 seconds
Step 3: Let charge for 12 hours
Step 4: Turn on and use the Kindle, if it shuts down before 6 to 8 hours of use, contact Amazon for a replacement.
Mar 26, 2013 | Amazon Kindle Fire HD
The kindle won't turn on
It is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't turn on at all this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
Dec 31, 2012 | Amazon Kindle Fire HD
Have a new Kindle 1. How long must we charge the battery before use?
It does not seem to take long at all, just 3-4 hrs. Check your on-screen charge indicator for further info.
Dec 26, 2011 | Amazon Kindle 1
Tablets & eReaders Logo
567 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
