Question about Garden
No spark on craftsman 10 hp eng
Was running before washing, put in new solenoid, eng switch, wiring, am not getting any spark, eng will turn over good. Thanks Gene gsbwham@yahoo.com
  • Joel Friedenberg May 11, 2010
    Is this an old tractor with points & condenser, or a more modern one with ignition module?
    President:
  • 1,627 Answers
Try a new ignition switch,needs to remove the ground to the coil while cranking.
Posted on Jul 23, 2009
Have a craftsman gs6500 lawn tractor with kohler 26 hp eng. need to know what the wiring for the ignition units and the gap setting. getting no spark from either coil.
You have a bad switch, i just had the same problem. One of your safety switches is grounding the coils so it wont start. there are 4 of them. One is under the seat, one is on the break pedal, one is the pto switch and the final one is the ignition switch.
Aug 15, 2011 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
I washed the mower an a spark flashed now it will not crank what would cause it to not start ?
if you got the solenoid wet you may have shorted it out, to check it follow the wire from the engine back to the ignition there should be a small device with several wires on it two thick ones and a few smaller ones. to test to see if the engine will still start put the key in the run position then carefully bride the gap between the two tick wires on the top of the solenoid with a screw driver. the engine should start and should have reset the solenoid if not then you may need to get it replaced.
Jun 30, 2011 | Craftsman 20 hp 42 in. Deck Yard Tractor
After 8 years in storage my 1982 Craftsman LTV 11 tractor will not start. (B&S vert shaft eng.) It would crank when jumping the solenoid, but not start even with switch in run position. I installed...
Not sure what all you have done. Most problems are in the carb. Did you replace with fresh gas? clean the carb. check for spark and compression. use ether or starting fluid into the carb air intake.
Jul 24, 2017 | Garden
Craftsman lt1750 with kohler cv491 engine. I have a new battery,checked the seat switch,made sure the brake was on and pto not engaged but I get nothing. Any ideas?
start solenoid def will it start if you jump it off by placeing the red possitive to the starter cable lug. the solenoid is about 15 dollars.
Aug 31, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
18hp kohler engine (grasshopper) won't start. Single click from starter/solenoid when key turned. Battery new/charged.
I have a duetz-allis mower with 18hp. kohler eng. won't start, have new seloniod, new circuit breaker, getting fire to switch & out. Still won'tstart
Aug 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 16.5 hp mower wont start. It had been running for about 20 min. then stalling. When I remove spark plug gas spills out hole. had fuel solenoid checked its ok. Could my coil be bad? carb has been...
I had similar problem, I found the wiring harness where it plugs into the ignition switch get loose and breaks contact. I replaced the wiring harness it fixed the problem for a while. Then replaced the ignition switch and it helped for a short time. Now I just open the hood reach behind the ignition switch and wiggle the wires while turning the key until it starts. Been working for me for 8to 10 years.
Jun 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
No spark on lawn tractor
have you bypassed the ignition switch?? if you by pass that switch and you get spark you know its the switch
Sep 28, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
