Question about Frigidaire Dryers
Model number fdgb23rgs2 gas dryer won't dry but tumbles, already replaced gas valve solenoids
  • 716 Answers
Watch The Igniter to see if it lights if it doesn't its the igniter if it does but goes out shortly replace the thermostat you can buy universal thermostats and igniter's at sears, home depot, Lowes And other hardware stores.
Sincerely,
Michael Scott
Posted on Jul 22, 2009
TUMBLE DRIER STOPPED HEATING
Gas dryer?
If so, probably bad gas solenoid valves. They can safely be replaced without fear of releasing gas. Two phillips screws, two pull off wire plugs. That's it. Cost about $30 bucks depending on where you buy them. They are a universal part and will fit 99.9% of machines.
www.repairclinic.com
Best of luck...
May 18, 2015 | Dryers
Is there a reset for the heat function
Below is a ''copy and paste'' of an answer I gave someone else:
If it is a gas dryer, there are two (round black colored) solenoid switches that control the gas flow. They go bad frequently, (and even more frequently when you buy cheap Chinese replacements). Replacing them is _very_ easy, and there is no danger of releasing gas while replacing them. (''Gas Control Solenoids''). The ''click'' you hear is the thermostat ''calling for'' the solenoids to turn on... the actual ''click'' is the ''igniter'' that would ignite the gas which is supplied by those solenoids. // Note: This problem usually shows itself with the dryer repeatedly re-igniting the gas during drying (i.e. ''lots of that ''clicking'' noise). Then, finally the solenoids die altogether and it never ignites even once. // In my opinion, this is the most common GAS dryer repair, and the easiest to repair. Each solenoid ''slides'' onto a post, and is removed the same way. // WARNING: the solenoid posts are a part of the ''GAS VALVE''. DO NOT remove any screws from the ''GAS VALVE''. ONLY remove the screw(s) on the bracket _above_ the solenoids (which is holding them in place). Once the ''hold-down'' bracket screws (sometimes just a ''hold-down'' screw... no ''bracket'' per say) are removed, the solenoids will pull right off of the posts, and replaced the same way. Just make sure you position them the same way; (i.e. ''make sure the connector for the wires are facing the same way as original''). // Ps... The full retail cost of a set of two is about $20 bucks, and as little as $5 bucks for the cheap Chinese replacements. Note: These _cannot_ ''leak'' gas. They work magnetically. They either work or they don't, but they do NOT ''leak gas'', including during removal. Just don't remove screws from the ''gas valve'' as I explained above.
Jun 08, 2014 | Siemens Dryers
Maytag atlantis gas dyer not heating
Can you look inside the door for your model number. I believe the problem is either a defective igniter or defective solenoid coils that open the gas valves=> 279834 Gas Valve Solenoid Set
4391996 Dryer-Igniter
Here is a Manual=> Atlantis_Neptune_Electric_and_Gas_Dryer_Service_Manual
I will be here if you have questions, Thanks Sea Breeze
Feb 28, 2013 | Dryers
Kenmore dryer thats not drying
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 01, 2010 | Dryers
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
Tumbling fine no hot air. is a gas dryer
First, check that the ignitor is working properly. It should glow visibly if it is working. If the ignitor seems to be functioning properly, then I would suspect the gas valve coils. These electrical coils are right above the gas valves and when these solenoids are energized they open the gas valves and permit the burner to light. If they are faulty, the gas valves don't open so no gas gets to the burner. Due to the difficulty in testing these solenoids, it is recommended that both (all) be replaced at the same time if any are suspected of being faulty. Hope this helps and best wishes.
Aug 11, 2009 | Dryers
Dryer is warm but not hot
Is the model number listed here or can you find the complete model number? May need cycling thermostat or gas valve solenoids. Let me know if I can help, Sea Breeze
Mar 22, 2009 | Maytag MDG16PD Gas Commercial Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer MDG5500AWW will not heat. Tumbles but no heat.
Could be any number of things .. igniter ( which lights the fire that dries your clothes) over-temp switches ( that disable the gas valve from opening and won't let a fire get started..) Defective gas valve.. not opening to let gas in for the fire that dries our clothes..
Those are the main components in your system and not much more I can provide to you unless I had specific details on what you've checked etc.. maybe this link will help identify the parts associated with your dryer... and if your so inclined..can do your own diagnostics... http://www.pcappliancerepair.com/model-display.php Hope that helps...
Aug 24, 2008 | Maytag Dryers
Dryers Logo
89 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
