The mid tones show up great but highlights and shadows show up as neon greens and reds. For example, on my screensaver is a picture of my son on my shoulders. he is wearing a bright yellow shirt and khaki shorts. The shirt and shorts show up as they should but, the highlights in his hair and shadows in his pockets show up as neon colors. Almost as if the picture has been polarized.
  • 585 Answers
You have a bad signal board
Posted on Aug 01, 2009
Tone of red is showing too much. like a red shadow behing people
try this: go to the menu go to picture change the tint by adjusting the red.
May 26, 2011 | Televison & Video
Our tv has red and green shadows on the picture when words come on at the bottom of screen they look like a shadow double Peoples faces will be outlined with red and green lines
your color engine is failing its also known as the optic block and they are very expensive to replace good luck google the optic block failure in these sets to better educate yourself with what your dealing with ok it most often blue that shows the failure but green and blue to and red
Dec 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Our 7 year old Sony TV KP-51W5510 has the following problem. Picture has 2 colors, writting has 2 colors the skin tone has 2 colors, writting on the screen will show 2 colors black and red in shadows pls...
a ladha,
You have lost the convergence circuitry. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which will explain the problem, tell you where to get parts and explain how to do the repair.
Thanks for using FixYa and for the great rating!!
hardrocko
Sep 12, 2010 | Sony KP-51WS510 51" Rear Projection...
Black and white negatives produce scans that show too much contrast......any suggestions?
1) Decide which problem is the worst: shadows too dark or highlights too light. 2) Run your scan with Nikon 4 software tool "Digital DEE" adjusted for EITHER Shadows or Highlights (not both; Highlights setting will "trump" a Shadows setting, even though you have a non-default setting at all DEE sliders).  Generally good choices for Shadows are 39 to 55. (39 = lighten the shadows a little; 55 = lighten the shadows a lot.) Experiment; do several scans. Generally good choices for Highlights are about 17 to 42 for amount and about 4 to 30 for threshold. (17/4 = dim the highlights a little; 42/30 = dim the highlights a lot.) Again, you have to experiment to get some experience. 3) When in Photoshop PSD format (After first doing a Levels adjustment): Try using the Adjustments/Shadows and Highlights tool to AGAIN brighten your too-dark shadows and/or tone down your highlights. (I.e., the effect is cumulative on top of your Digital DEE effect. But Digital DEE is a more "magical" feature and is somewhat preferred to PS's Shadows and Highlights tool. DEE, however, will often produce an annoying "light smear" [bright area "dragged" into an adjoining darker area]. In case of a "light smear" from DEE, do not use the tool; too hard to fix.  Use PS's Shadows & Highlights tool instead.)  4) Proceed with other PS adjustments such as Curves, etc.  5) Still not satisfied?  Go to Levels again and look at your histogram. Is it really "stacked" to one side or the other (a mountain way over at the left or at the right)? You might want to try the rather severe command of Adjustments/Equalize.  This "spreads out" your pixels more evenly across the histogram. Note: this is a scary adjustment that requires misc fixes to tone-down certain aspects of the Equalization adjustment.  No free lunch, right? 6) After experimenting with the above tools, you should be able to get a handle on too-contrasty pictures. There will be a learning curve.
Sep 18, 2009 | Nikon Super Coolscan 5000 ED Film Scanner
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Aug 06, 2009 | Televison & Video
HP z2100 horizontal lines where the text or object are
Check for updated firmware and drivers. Also, if all your object and text or black try changing them to color and see if that helps, maybe there is something wrong with your black printhead, the black may not be used when printing photos, the printer may be using process black for photoes and real black for black text and objects.
Oct 08, 2008 | HP DesignJet Z2100 InkJet Photo Printer
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Mitsubish hd 1080I wt 46809
Check settings first to make sure no one changed anything out of the ordinary. Are the shadows that of a color or darkened shadow? It could be out of convergence, which can be corrected in the menu - or it could be low quality video cables to. Also, if there is no green, does a white color show up when you're in a menu mode (Red+Blue+Green = White Image)? If so, then the green picture tube is working and it's just a color adjustment, otherwise you may have to invest in a new green picture tube.
Apr 22, 2008 | Televison & Video
Televison & Video Logo
297 people viewed this question
Top Televison & Video Experts
Electro Med Services...
