Computers & Internet Logo
Rico St. Aubin Posted on Feb 20, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PowerShell Script that lists the local administrators on a machine.
Robert Karst
Level 2:
Scholar:
  • Expert 151 Answers
  • Posted on Feb 23, 2017
Robert Karst
Expert
Level 2:
Scholar:
Answers
151
Questions
0
Helped
40628
Points
473
NET HELPMSG 2182. System.Management.Automation.RemoteException
The error message "NET HELPMSG 2182. System.Management.Automation.RemoteException" typically occurs when there is an issue with executing a remote command in PowerShell. Here are some steps you can try to resolve this error:
Check network connectivity: Ensure that you have a stable network connection and that the remote computer is accessible. You can do this by pinging the remote computer to see if you get a response.Check remote execution policy: Make sure that the remote execution policy on the target computer is set to "RemoteSigned" or "Unrestricted". You can check the remote execution policy by running the following command in PowerShell:
Get-ExecutionPolicy -Scope RemoteMachine Run the command as an administrator: Some commands may require administrative privileges, so try running the PowerShell prompt as an administrator and then executing the command again.Verify the remote computer name: Ensure that the remote computer name is correct and that you have permission to access it.Disable the Windows Firewall: If the Windows Firewall is enabled on the target computer, try disabling it temporarily to see if it is causing the issue. You can do this by running the following command in PowerShell:
Set-NetFirewallProfile -Profile Domain,Public,Private -Enabled False Enable CredSSP authentication: CredSSP (Credential Security Support Provider) is an authentication method that is used for remote commands. You can enable CredSSP authentication by running the following command in PowerShell:
Enable-WSManCredSSP -Role Client -DelegateComputer * If none of these steps resolve the issue, it may be necessary to consult the error logs or seek assistance from a professional administrator.
2answers
How to stop windows 11 from Automatic Update?
To disable Windows 11 automatic updates, open Settings > Windows Update, and click the "Pause for 1 week" button to disable updates. You can also use Group Policy or Registry to disable automatic updates you can google your question for more info and details
2answers
What to do when installing windows 10 on asus laptop and mousepad just disappear..how to get it back
Wait until the installer prompts you. The generic mouse driver in bios is not good for the mouse you are using.
List of commands for vista
CMD command list
http://ss64.com/nt/
Run command list
to open run Press and hold start button on keyboard and while holding start button press R just once, small run window will popup and you can type the commands inside the run box and press enter on keyboard or click ok to execute the command.
Administrative Tools
Administrative Tools = control admintools
Authorization Manager = azman.msc
Component Services = dcomcnfg
Certificate Manager = certmgr.msc
Direct X Troubleshooter = dxdiag
Display Languages = lpksetup
ODBC Data Source Administrator = odbcad32
File Signature Verification Tool = sigverif
Group Policy Editor = gpedit.msc
Add Hardware Wizard = hdwwiz.cpl
iSCSI Initiator = iscsicpl
Iexpress Wizard = iexpress
Local Security Settings = secpol.msc
Microsoft Support Diagnostic Tool = msdt
Microsoft Management Console = mmc
Print management = printmanagement.msc
Printer User Interface = printui
Problems Steps Recorder = psr
People Near Me = p2phost
Registry Editor = regedit or regedt32
Resoure Monitor = resmon
System Configuration Utility = msconfig
Resultant Set of Policy = rsop.msc
SQL Server Client Configuration = cliconfg
Task Manager = taskmgr
Trusted Platform Module = tpm.msc
TPM Security Hardware = TpmInit
Windows Remote Assistance = msra
Windows Share Folder Creation Wizard = shrpubw
Windows Standalong Update Manager = wusa
Windows System Security Tool = syskey
Windows Script Host Settings = wscript
Windows Version = winver
Windows Firewall with Advanced Security = wf.msc
Windows Memory Diagnostic = MdSched
Windows Malicious Removal Tool = mrt
Computer Management
Computer Management = compmgmt.msc or CompMgmtLauncher
Task Scheduler = control schedtasks
Event Viewer = eventvwr.msc
Shared Folders/MMC = fsmgmt.msc
Local Users and Groups = lusrmgr.msc
Performance Monitor = perfmon.msc
Device Manager = devmgmt.msc
Disk Management = diskmgmt.msc
Services = services.msc
Windows Management Infrastructure = wmimgmt.msc
Conrtol Panel
Control Panel = control
Action Center= wscui.cpl
Autoplay = control.exe /name Microsoft.autoplay
Backup and Restore = sdclt
Create a System Repair disc = recdisc
BDE Administrator = bdeadmin.cpl
Color Management = colorcpl
Credential Manager = control.exe /name
Microsoft.CredentialManager
Credential Manager Stored User Names and Passwords = credwiz
Date and Time Properties = timedate.cpl
Default Programs = control.exe /name Microsoft.DefaultPrograms
Set Program Access and Computer Defaults = control appwiz.cpl,,3 or ComputerDefaults
Devices and Printers = control printers
Devices and Printers Add a Device = DevicePairingWizard
Display = dpiscaling
Screen Resolution = desk.cpl
Display Color Calibration = dccw
Cleartype Text Tuner = cttune
Folders Options = control folders
Fonts = control fonts
Getting Started = GettingStarted
HomeGroup = control.exe /name Microsoft.HomeGroup
Indexing Options = control.exe /name Microsoft.IndexingOptions
Internet Properties = inetcpl.cpl
Keyboard = control keyboard
Location and Other Sensors = control.exe /name
Microsoft.LocationandOtherSensors
Location Notifications = LocationNotifications
Mouse = control mouse or main.cpl
Network and Sharing Center = control.exe /name Microsoft.NetworkandSharingCenter
Network Connections = control netconnections or ncpa.cpl
Notification Area Icons = control.exe /name Microsoft.NotificationAreaIcons
Parental Controls = control.exe /name Microsoft.ParentalControls
Performance Information = control.exe /name
Microsoft.PerformanceInformationandTools
Personalization = control desktop
Windows Color and Appearance = control color
Phone and Modem Options = telephon.cpl
Power Configuration = powercfg.cpl
Programs and Features = appwiz.cpl or control appwiz.cpl
Optional Features Manager = optionalfeatures or control appwiz.cpl,,2
Recovery = control.exe /name Microsoft.Recovery
Regional and Language = intl.cpl
RemoteApp = control.exe /name
Microsoft.RemoteAppandDesktopConnections
Sound = mmsys.cpl
Volume Mixer = sndvol
System Properties = sysdm.cpl or Windows logo key + Pause/Break
SP ComputerName Tab = SystemPropertiesComputerName
SP Hardware Tab = SystemPropertiesHardware
SP Advanced Tab = SystemPropertiesAdvanced
SP Performance = SystemPropertiesPerformance
SP Data Execution Prevention = SystemPropertiesDataExecutionPrevention
SP Protection Tab = SystemPropertiesProtection
SP Remote Tab = SystemPropertiesRemote
Windows Activation = slui
Windows Activation Phone Numbers = slui 4
Taskbar and Start Menu = control.exe /name
Microsoft.TaskbarandStartMenu
Troubleshooting = control.exe /name Microsoft.Troubleshooting
User Accounts = control.exe /name Microsoft.UserAccounts
User Account Control Settings = UserAccountControlSettings
User Accounts Windows 2000/domain version = netplwiz or control userpasswords2
Encryption File System = rekeywiz
Windows Anytime Upgrade = WindowsAnytimeUpgradeui
Windows Anytime Upgrade Results = WindowsAnytimeUpgradeResults
Windows CardSpace = control.exe /name Microsoft.cardspace
Windows Firewall = firewall.cpl
WindowsSideshow = control.exe /name Microsoft.WindowsSideshow
Windows Update App Manager = wuapp
Accessories
Calculator = calc
Command Prompt = cmd
Connect to a Network Projector = NetProj
Presentation Settings = PresentationSettings
Connect to a Projector = displayswitch or Windows logo key + P
Notepad = notepad
Microsoft Paint = mspaint.exe
Remote Desktop Connection = mstsc
Run = Windows logo key + R
Snipping Tool = snippingtool
Sound Recorder = soundrecorder
Sticky Note = StikyNot
Sync Center = mobsync
Windows Mobility Center (Only on Laptops) = mblctr or Windows logo key + X
Windows Explorer = explorer or Windows logo key + E
Wordpad = write
Ease of Access Center = utilman or Windows logo key + U
Magnifier = magnify
Narrator = Narrator
On Screen Keyboard = osk
Private Character Editor = eudcedit
Character Map = charmap
Ditilizer Calibration Tool = tabcal
Disk Cleanup Utility = cleanmgr
Defragment User Interface = dfrgui
Internet Explorer = iexplore
Rating System = ticrf
Internet Explorer (No Add-ons) = iexplore -extoff
Internet Explorer (No Home) = iexplore about:blank
Phone Dialer = dialer
Printer Migration = PrintBrmUi
System Information = msinfo32
System Restore = rstrui
Windows Easy Transfer = migwiz
Windows Media Player = wmplayer
Windows Media Player DVD Player = dvdplay
Windows Fax and Scan Cover Page Editor = fxscover
Windows Fax and Scan = wfs
Windows Image Acquisition = wiaacmgr
Windows PowerShell ISE = powershell_ise
Windows PowerShell = powershell
XPS Viewer = xpsrchvw
Open Documents folder = documents
Open Pictures folder = pictures
Open Music folder = music
Open Videos folder = videos
Open Downloads folder = downloads
Open Favorites folder = favorites
Open Recent folder = recent
Logs out of Windows = logoff
Locks User Account = Windows logo Key + L
I have downloaded a file WINDOWS POWERSHELL that has an .msu extension how do i install this package in my winxp professional sp2 os.
.MSU is a Microsoft UPDATE file....designed to be downloaded and installed as part of Windows Update.
I suggest you run the Windows update and choose which items you want to install from the list (assuming it includes Powershell) otherwise, locate a standalone installer for the powershell, which should have a .MSI or .EXE extension.
Good Luck
2answers
How can i configure the Ip address and dns in dos mode
netsh [-a AliasFile] [-c Context] [-r RemoteMachine] [Command | -f ScriptFile]
? Displays a list of commands. add Adds a configuration entry to a list of entries.
add helper Installs a helper DLL. delete Deletes a configuration entry from a list of entries.
delete helper Deletes a helper DLL. dump Displays a configuration script. exec Runs a script file. help Displays a list of commands. interface Changes to the `interface' context.
ip Changes the 'interface ip' context. ras Changes to the `ras' context.
aaaa Changes to the `ras aaaa' context. appletalk Changes to the `ras appletalk' context. ip Changes the 'ras ip' context. ipx Changes to the `ras ipx' context. netbeui Changes to the `ras netbeui' context. routing Changes to the `routing' context.
ip Change to the 'routing ip' context. ipx Changes to the `routing ipx' context. set Updates configuration settings.
machine Sets the current machine on which to operate. show Displays information.
show alias Lists all defined aliases. show helper Lists all the top-level helpers.
Available commands after you have entered the netsh command (typing netsh at the prompt and pressing enter).
.. Goes up one context level. ? Displays a list of commands. abort Discards changes made while in offline mode. add Adds a configuration entry to a list of entries. alias Adds an alias. bye Exits the program. commit Commits changes made while in offline mode. delete Deletes a configuration entry from a list of entries. dump Displays a configuration script. exec Runs a script file. exit Exits the program. help Displays a list of commands. interface Changes to the `interface' context. offline Sets the current mode to offline. online Sets the current mode to online. popd Pops a context from the stack. pushd Pushes current context on stack. quit Exits the program. ras Changes to the `ras' context. routing Changes to the `routing' context. set Updates configuration settings. show Displays information. unalias Deletes an alias. Examples
netsh Enter the netsh command. netsh dump Dump all the network information as a script to the screen. Can also be sent to a file by doing netsh dump > file.txt . This script can then be executed using the exec command. set address name="Local Area Connection" source=dhcp Set the "Local Area Connection" to DHCP. set address local static 10.0.0.9 255.0.0.0 10.0.0.1 1 Set the local address to Static. netsh interface ip show config View network ip configuration. Below is an example of what may be seen. Configuration for interface "Local Area Connection"
DHCP enabled: Yes
InterfaceMetric: 1
DNS servers configured through DHCP
WINS servers configured through DHCP
Best way to remove local profiles from over 1000 in windows xp OS
Happy Holidays
well, here is a security issue, and administration policies.
I recommend you should talk, with the administrator of this locals machines, to do this. depending on LAN or place, its a privacy and security issue. but yes, depending the rank you have to make changes on cumputers, or what you really want to do, on that computers, there is no tools for that but make policies. as administator
Not opening drives
You are sure your user has administrative privilages on the local machine?
Right click My Computer
Click Manage
Click Users and Groups
Open Groups
Open Administrators
Are you listed, or a group your a member of listed?
Top The Computers & Internet Experts
Alexander
nexrad_chris
vince
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
