Question about Bosch Axxis WTL 5410 Electric Dryer
Groaning sounds when dryer spins
When I turn my dryer on, it starts and will spin but makes horrible sounds every time if goes around. If I turn it off and then manually spin the insides in either direction, it makes the same sound. It seems like the sound is coming from the inside back of the dryer but I'm not sure.
  • julie2_68 Nov 25, 2007
    doesn't sound good, but thanks for letting me know what's wrong with it!
  • 213 Answers
Yes it is, its the rear tub bearing. pain in the butt to change but that will solve it
Posted on Nov 20, 2007
Makes horrible groaning noise during wash spin
Hi, it sounds like you need the drum bearings replaced.
Feb 16, 2016 | Washing Machines
My admiral washer model atw4475tq0 is having trouble spinning and i also have a admiral dryer atw4475tq0 that is making a thumping sound
washer: check clutch assembly links with instructions here
dryer: check support weels (2) for a flat spot or if theyre hard to turn
Dec 11, 2014 | Admiral Washing Machines
I have a Maytag (Model MTW5770TQ0) washer. It
yes it sounds like it try this when running open lid if it
does what you say its doing then the transmission needs to be replaced this contains the clutch and it may be cheaper to replace the washer call a repairman
Nov 24, 2009 | Washing Machines
When my washer goes into the spin cycle, it vibrates horribly.
sounds like you have a transmission problem. yes, i said transmission. washers have a centrifical gearing system which acts like a transmission. what you describe sounds like a bad bearing. definately a job for the repairman. good luck
Jun 10, 2009 | Maytag LSE7806A Top Load Stacked...
Dryer making funny noise
If your dryer is old, your probably right. Your drum rolls on 3 rollers and they tend to get "out of round" after years of use. If you want to change them, you will have to remove the drum from the front of the dryer (after removing the door) and they will be attached to the rear wall. Good luck. Your fix it cost is around....$50.
Apr 16, 2009 | Whirlpool LER5636P Electric Dryer
Dryer quit, makes groaning sound when you push start button and
The motor bearings are probably shot. You can try to get it going by oiling the motor but you will have to make some holes. The cotton wells are sealed around the bearings. I use a 1/8th inch drill bit being careful not to hit the shaft. I refill the cotten wells with a high temp resistant oil that does not evaporate and is used for HVAC applications. It is called zoomspout oil. $2 at any ace hardware store. After oiling the motor you must work it free till it spins nicely on its own. Then oil the rollers and idler. Wiith any luck you will save some money. Here is a site that tells how to access dryer and a whole lot more.
Apr 09, 2009 | Dryers
Noisy Dryer
You'll have to take the back off and fisically look and see if a pulley is bad. Hoped this helped, if not let us know thankyou for asking.
Mar 14, 2009 | GE Dryers
Kenmore HE2 Elite is making groaning noises and then error messages 5D and/or F
did you clean pump out by removing acess port on front end of pump? also you can ckd pump impeller by removing screws around pump body impeller will free wheel but should have some resistance to turning by hand if no water in tub reinstall pump put in drain spin to see if drum will spin if it does forget main motor ..motor is most reliable par on those washers
Aug 06, 2008 | Kenmore Elite 45986 Front Load Washer
Thumping/knocking/rattles during wash agitation cycle
Mine is doing the same thing. I opened it up to see what was happening and it was the drive belt tension arm bumping around. Soon, the belt started slipping during the spin cycle. Now it won't spin and the belt starts to smolder from the friction of the drive motor. If you haven't checked your belt, that's a good place to start.
Jun 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
1999 maytag intellidry gas dryer
The groaning sound seems as if the belt is broaken and the motor is trying to spin a little too fast because it doesn't have a load on it. Take a look to see if the belt is broken and if so, you can purchase a replacement belt at Lowes for approximately $7.00.
Mar 15, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Bosch Axxis WTL 5410 Electric Dryer Logo
217 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
