Question about GPS
RAN A HARDWIRE FOR MY GARMIN GPS BEHIND THE CENTER VENT ON MY HUMMER H3. NOW THAT I HAVE IT BEHIND THE DASH IT'S HANGING BY MY FEET AND DON'T KNOW WHERE TO CONNECT THE WIRES?
  • 1 more comment
  • wynne29 Jul 23, 2009
    It is a nuvi 770. but I don't think that's relevant. what I need to know is where to connect the black and red wires to get power. I want the power to shut of when th ignition is off.
    No good ! I have a 2008 Hummer H3 with no cigarette lighter. I do have 2 12V power connections, however they do not turn off with the ignition. Need another source ID'd
  • wynne29 Jul 24, 2009
    this sounds fine. except the fuse box is in the engine compartment and i see no easy way through?
    President:
  • 1,723 Answers
There is really only one way to find a switched hot, and that's to use a meter under the dash. You will have to locate a 12 volt+ wire and then turn the key off to check it. It's that or use a 'wire clothes hanger,' straighten it out and push a wire through the fire wall, there are some holes going through already. It's doable. Then just route it over to the fuse box, and there are plenty of options there. It is really the way to go here. if you take it in to the shop, this is what they'll do, so you may as well do it and save a bundle. The black wire just goes to a ground point (any screw).
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 24, 2009
  • 520 Answers
The best way to solve this is go straight to the fuse block. There is a "bus jumper" made for this application. A buss jumper is a little metal piece that fits in the slot with the fuse and lets you tie a wire in with its power source. You will need to use a multimeter or a test light to identify which fuses have power only when the ignition is on. Tie the buss jumper in to that fuse and re run the wire to the GPS. Now when you turn off the key the power on the unit will die. Hope this helps. Please re-post with updates or questions. If you feel that this solution has then please accept and rate. Thanks cj2176.
Posted on Jul 23, 2009
  • 285 Answers
Can you please tell me what model Garmin GPS you have?
Posted on Jul 22, 2009
  • Dean
    Dean Jul 23, 2009
    Well the wires are for a 12 volt power supply to hook up to your cigarette lighter outlet. So if you wired those to your cigarette lighter plug correctly (red for positive, black for negative/return) then the cigarette lighter plug should also be wired to your ignition system to only apply power when the key is in the ignition etc.
Driving and Rpms go up
Dealer Checked my Hummer. They said all H3's have the same problem ...
www.elcovaforums.com > ... > General H3 Discussion
Sep 15, 2005 - 24 posts - ‎17 authors
rattling sound inespected in my hummer because ... go uphill or press on the gas pedal to ... same time up to 2500 rpm on my H3. .... Buzz or Rattle Noise While DrivingUnder Load from the Exhaust ... 2006 Hummer H3
Slow Gear Shift, Low RPM - Normal for H3? - Hummer Forums ...
www.hummerforums.com > ... > Hummer Lineup > Hummer H3
Mar 6, 2012 - Hey All! I recently bought a used 2007 H3 (automatic). ... for h3"!!.if it dont feel normal,,it aint!! im driving my 2nd h3 and they both felt ... 2006 Hummer H3... you can tell when locked up. go ez on gas and rpms dont jump,they ... Hummer H3 Won't get above 2.5 RPM - Hummer Forums ...
Jun 26, 2014
My h3 loses power and sometimes turns off when i turn
Mar 16, 2010
More results from www.hummerforums.com
RPM bouncing from idle. Caused short bursts of "unintended ...
Jan 01, 2016 | 2006 Hummer H3
Anyone tell me please where to get the programming which we use to setup hummer h3 body module?
Phone around Yellow Pages to find a dealer who might be able to help you. The service centre that sold you the unit should have some idea to be able you to contact a Company that can do what you require..
Dec 09, 2015 | Hood Vent Deck 403506 - H3, H3T, HUMMER,...
Have a 06 H3 it wont lock in 4x4 High or low
Hummer X Forum • View topic - H3 no 4x4 at all! - Hummer X Club
www.hummerxclub.com/forum/viewtopic.php?f=25&t=12166
Feb 15, 2010 - 15 posts - ‎7 authors Well another high center incident, #3 for Tink, in her 2006 H3. ... "No SERIOUSLY, don't follow me, you WON'T make it" ... The systems on the H3 are designed to try and lockup wheels via the brakes to allow max torque to the ... 2006 h3 wont start :/
Dec 31, 2010
4 Wheel Drive Applications for H3 ...
Feb 15, 2010
stuck in high 4 lock ?
Apr 24, 2009
H3 Steering Problem
Mar 25, 2009
More results from www.hummerxclub.com
Oct 01, 2015 | 2006 Hummer H3
Where is the inside fusebox located on a h3 hummer
The hummer H3 has only one fusebox which is inside the engine compartment behind the battery
May 22, 2014 | 2008 Hummer H3 Adventure
Hummer h3 radio
I think it must be in theft lock, contact a GM dealer.
Mar 18, 2014 | 2006 Hummer H3
I have a 2010 hummer H3. the doors message is on the dash and the interior lights wo't shut off. of course we checked all of the doors. is there a quick fix? the service dept is closed all weekend
you have a bad door ajar sensor dont know which one it is until you replace one if it doesnt go off then replace old one and go to next one
Sep 18, 2010 | 2006 Hummer H3
Hummer h3 ac, heater quit blowing just overnight is there more than one fuse for the ac or what could it be?
Turn the fan on and hit the fan motor a tap with your hand .. if it starts up you know it needs replacing .
Jul 22, 2010 | 2006 Hummer H3
06 hummer h3-water on passenger floor after a rain
Hey I have the same problem, but only when it rains, it comes from the sunroof then leaks into the carpet.
Aug 17, 2009 | 2006 Hummer H3
BRAKE SYSTEM FAILURE
well what could of happend they probably put the battery on backwards and blew out a fusible link.The links run thru the wires by the battery and behind the alternator check it out Good Luck keep me posted
May 27, 2009 | 2006 Hummer H3
Can a 2007 h3 hummer be towed behind an rv
not as easy, but possible.. the best ones to tow are a wrangler or any saturn car,or suv..good luck keith...
Mar 14, 2009 | 2008 Hummer H3
GPS Logo
49 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
