Question about Printers & Copiers
Msds for 4G Black Toner and for Xante 8300
Good Afternoon,
I am looking for Material Safety Data Sheets for the above products.
I would appreciate any help that you could give me.
If you could send this information any way that you would like.
My e-mail address is:
Fax # is:
Or you could send information to:
Houston Chronicle
Attn: Becky Cornell
801 Texas Ave.
Houston, Texas 77002
Thank you I appreciate your assistance on this matter.
Becky Cornell
  • 163 Answers
Re: msds for 4G Black Toner and for Xante 8300 - Printers & Copiers
I hope the info on the MSDS helps.
Posted on Dec 11, 2007
0 characters
3 Points
"xante ilumina fatal error 929"
The 929 fatal error
Waste Toner
Transfer Motor
Lock Error.
The waste toner transfer motor is not operating properly. Does the error still occur? Yes
Check to confirm that the waste toner transfer system is operating properly.
Replace the waste toner motor.
Feb 03, 2013 | Xante Ilumina Digital Color Press Printer
I found msds resources at, I'm not sure of the question, can you be a bit more specific ?
Thank you
Nov 03, 2010 | Printers & Copiers
How many pages per minute doe it print?
Black Print Speed:--------- 15 ppm***** Total Media Capacity:---- 250 Sheets****** Max Resolution (BW):---- 600 x 600 dpi*********
Being laser-based, the SCX-4100 is a more economical choice over bubble jet printer whose cartridges are expensive in comparison to their durability. But be mindful that the SCX-4100 is a black-and-white device – so no color printing/copying for you, although it obviously scans color documents. The toner cartridge is good for about 3,000 copies, a figure that can increase 40% with toner management software (included).
The device has a main paper tray that holds 250 sheets up to legal size. You can manually feed a sheet at time into a slot right above the front paper tray, and there’s also a rear slot for jam-prone material, like envelopes and transparencies. Unfortunately, the SCX-4100 lacks an automatic document feeder.
Thanks. you can rate this solution and show your appreciation.
May 18, 2010 | Samsung SCX-4100 All-In-One Laser Printer
Xante accel-a-writer 4g for mac OSX 10.6
I haven't checked in a while. Xante told me when I called them that they were not planning to make updates past the current version of the 4G OS X drivers, as the machine was no longer in production. They said the driver should perform adequately on current versions of OS X even though it was not initially designed for them (as they did not exist when the driver was created).
I found this to be untrue in my case. The drivers did not allow me to print consistently from 10.5.8 on an Intel Mac Pro.
My solution was to activate the print server on an Xserve running the Tiger server version of OS X, install the Xante driver there (since it was designed to run on that version of the OS), and now my newer macs can use the printer without issue.
Apr 20, 2010 | Xante Accel-a-Writer 4G Laser Printer
Just tell me how to get the Material Safety Data sheet for the cannon ir 400
This link has the MSDS for the toner. I beleive it is the only MSDS available or that you would need.
About 3/4 the way down the page.
Nov 24, 2009 | Canon imageRUNNER 400S Copier
The printer itself won't have an MSDS report. Each of the toners and supplies come with MSDS sheets, or the address and phone #'s to obtain them from Samsung.
Jun 19, 2009 | Samsung SCX-4300 Monochrome Laser...
Fuser is bad...actually, the paper jam sensor is bad. can I use a fuser from a different printer
Yes, most likely they do. I don't believe there is much if anything that differentiates one toner from another other then the size of the roller and the shape of the cartridge. If these are the same and given that they use the same fuser, I would definitely try it.
Aug 08, 2008 | Xante Accel-a-Writer 4G Laser Printer
Screens Picking off on press
the problem is due to the fuser not to anything else seems that the fuser do not heat up the toner enough, what i did is to run the plate twice , as blank of course . it did the trick for my press.
Apr 23, 2007 | Xante PLATEMAKER 4 Laser Printer
Printers & Copiers Logo
334 people viewed this question
Top Printers & Copiers Experts
old marine
old marine
Are you a Printer and Copier Expert? Answer questions, earn points and help others
