SOURCE: My washmachine smells horrible. My
there is nothing in a washer to smell - just stainless steel, rubber and plastics!
check the following:
are you using liquid detergent? if so after extended use, the machine smells like drains. put on the hottest wash with no clothes and smell will go. revert to using powder.
check there is a water barrier between the drain hose and your main drain. if not, the smell of your sewer will come up thro the drain hose.
is the drain connected to a spigot off the sink trap and do you have a waste disposal unit? these stink and unless you again have a water barrier the smell will come thro the drain hose
SOURCE: xbox has burnt electrical smell
my xbox power is 100v and i connected it to 200 v
waht shal i do
SOURCE: when I press the start button it smells like it is burning
if the is a convection model then the covection coill will smell that way if there is a geese build up and should be ok to use. however you should only smell that if you are using the convection mode.
SOURCE: really bad blue smoke coming from exhaust smells really bad
it's burning oil the problem is either a burnt valve or piston rings
SOURCE: my oven makes an electrical burning smell when
how old is the unit and can you hear any odd electrical arcing noise from the unit,? outside of the usual low hum of the elements heating up?
