Question about Pride Mobility Products Health & Beauty
I have a scooter and it was working perfectly but now i plug in the charger and doesen´t charge what should i do?
  • 175 Answers
Assuming you didn't get the PC board mounted inside the top of the tiller assembly wet, or the power controller located under the shroud, then you likely either have one or two of the batteries that are bad, or a bad charger. You will need a voltage tester that you can pick up cheap for about $6.00. Set to the DV voltage setting in the 50-100 volt scale. Remove the seat and the shroud and test the voltage at each battery. If good, they should read about 12.25 volts or more, not higher than 14. If one is normal and the other lower, say 10 Volts, that low one is bad, but you should probably replace both with fresh gel batteries, fully charge before using. If both batteries are about 12 VDC, then plug in the charger to the chair as usual, and take another voltage test on each battery. The voltage should read higher now that the charger is on. If they aren't, then your charger has no output. Some chargers you can test output voltage on without them plugged in by testing across the two horizontal pins on the 3-pin connector that you plug into the chair. The output voltage should be about 26 volts. If it is 24 or less, you need a new charger. Good luck.
Posted on Jul 24, 2009
How do I charge a moxie power scooter??
  • Turn the scooter's power switch to the OFF position.
  • Connect the charger's plug to the charging port on the scooter.
  • Plug the charger's power cable into a power outlet.
  • When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
  • Times recommended for your scooter.
  • Stop charging when the LED light is completely green.
  • Disconnect charger from the scooter, then from the power outlet.
  • Run your scooter before riding it to verify the battery charge.
Feb 02, 2016 | Health & Beauty
Tip
Charging your power chair or scooter the correct way can make them last
Whenever you need to charge your power chair or scooter get into the habit of charging overnight. The battery level indicator lights will tell you if your chair or scooter needs charging. Whenever the lights are down into the yellow and especially if they are in the red. If you have the off-board charger, plug the charger into the charger port in the front of your joystick and then plug the charger into the wall socket or turn the on/off switch on and let it charge overnight. When you get up in the morning the charger should have a red light(power) and a green light illuminated (indicating fully charged) Always turn the charger off or unplug it from the wall socket before you unplug it from the chair or scooter. Never have the power on to the charger when you plug or unplug it from your chair or scooter. Whenever you get new batteries always give your batteries a full charge before use and then if you use the chair daily charge it every night. If you do not use your chair or scooter daily charge it at least once a week. Never leave the charger plugged in and on for more than 24 hours. Your batteries should last you 3-4 years if you charge them correctly.
on Sep 20, 2010 | Health & Beauty
I am charging my scooter and it is beeping what do i do
Charge without the key on. Make sure your charger is applying power to the scooter. It may have a blown fuse or some other internal problem. If your batteries were totally discharged your charger will not recharge them. You'll have to charge them individually with an automotive style battery charger that is NOT an automatic charger. It may take 3 days continuous charging to recover enough charge before your scooter charger will continue to charge until the batteries are fully charged. If this doesn't work then the batteries will never take a charge nad need to be replaced.
Oct 15, 2014 | Health & Beauty
Scooter not charging when plugged into the charger
measure the voltage of the batteries thru the charging socket of the scooter, the outside 2 pins.
Sep 20, 2014 | Health & Beauty
Can you charge scooter without taking the batteries out? Is there an exterior spot to plug in?
You can charge the batteries with your offboard charger and the battery pack still on the scooter just plug the charger into the charger port on the side of the battery case and then plug it into the wall socket and charge overnite Will work just like if you removed the battery pack from the scooter. Hopw this helps you
Mar 26, 2011 | Pride Value Line Revo Scooter 3 Wheel
How do I charge my scooter I have lost my instructions
Look in your manual if you lost it then, go to razor.com and request one. But the simple answer is to:
1. Turn off the scooter
2. Plug charger into wall outlet.
3. Find the hole on the side that matches the charger plug(not the wall outlet plug) .
4. Plug the charger into the scooter.
5. Wait until the charger turn off ( if the charger is a smart charger), typical charging time is 4-6hours.
*If not a smart charger you can calculate the charge time by using an online battery charging time calculator.
Jul 02, 2010 | Razor E100 Electric Scooter
My Schwinn S-180 scooter won't charge
Check your charger with a meter and see if it is putting out the correct voltage for your scooter battery. If it is, you probably need a battery, probably so anyway after 2 years. Good luck!
Mar 16, 2010 | Transport Schwinn Rechargeable Portable ...
Travel Pro Scooter charging problem. I plug in the charger there is no light indication on the charger when it is plugged into the scooter or when it is unplugged from the scooter. Batteries will not...
hi , sounds likek a charger problem but if you have tried another charger then check the charger plug connection where the charger plugs in,
Check the batteries are connected correctly.
Regards
GeWiz.
Jan 13, 2010 | RTO Mega Motion 3 Wheel Travel Pal Scooter
My invacare auriga 3 wheel scooter will not work got 2 new batteries but will not power light flashing on charger as if charging but when put key in not even lights comne on
hi,
Can you clarifly what happens you plug in the charger in ?
Are you sure the fuses on the battery leads are okay ? the is one for each battery like a glass container ? check they have not blown, check the connections to the battery , are they tight ?
Regards
gewizrepairs.co.uk
Nov 14, 2009 | Pride New Mobility Legend 4 Wheel Scooter
How to charge my creative zen mp3 player
Just connect your Zen onto your PC (NOT LAP TOP) on a USB.
If does not start charging (you´ll see arrow and pause/ play buttons flashing slowly) then you need to RESET your ZEN.
How to reset: You´ll find a tiny little hole by on/off button on the side. With ZEN connected to the PC USB or onto wall charger try turning ZEN on, it doesen´t matter if it turns on or not. Then insert a sowing pin or office paper clip end in this reset hole for a few seconds and release. Give it a couple of seconds and see the lights go off onto charging mode. LEAVE IT CHARGING for 24 hours. Make sure your PC will NOT turn itself on safe mode or hibernates in this period, it has to be ON for charging, at all times.
This is it.
Louise Passalacqua.
Jul 08, 2008 | Creative Labs ZEN V Plus MP3 Player
Health & Beauty Logo
136 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
