Question about Samsung Syncmaster 275T Monitor
Screen turns on for a second then flashes off. Just saw a post that said this could be a capacitor problem. The Monitor is the 225bw not the 275t
  • Samsung Master
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitorswillblow a power supply. The problem is caused by parts called capacitorsoverheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine.You should find 5 bad capacitors. If you can take a picture or two of your board and email them to me I can tell you what to replace. The capacitors do need to be installed with the correct + and- connections, note the stripe on the old one and insert the new onethe same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 23, 2009
Samsung syncmaster 275t won't start - what to do?
The Samsung monitor is okay, the problem is a compatability issue between the laptop and monitor. The VGA toDVI is the problem you are converting a analog signal to digital, the signal level degrades when that is attempted. If I understand this the laptop puts out the analog signal "VGA" and the monitor has the DVI input, "digital" The only other suggestion is turn off the laptop screen to see if the monitor will work.
Apr 04, 2012 | Samsung Syncmaster 275T Monitor
Blank lcd screen when turned on . Wonder if backlight problem
A blank screen is usually caused by the power supply not giving the right voltages to the back light inverter, the bulbs last a lot longer than the power supply board. If you can do a little soldering then you should be able to do the repair yourself. Here is a link to a repair guide that shows how to dis-assemble the unit and get to the power supply board. There are 5 capacitors that will need to be changed and in most cases this will fix the type of issues you are having with this monitor.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-225bw-22-monitor/
BuddyMc
Dec 22, 2010 | Samsung 225BW LCD Monitor
My samsung 225BW only shows for one second after i open my computer. What should i do? Also if i turn the moniter off and on it will show for one second and disappear. What should i do? Thanks
It probably has bad DC filter caps just like the rest of failed SAMSUNG monitor as shown in my albums, that will be the first thing to look for.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Nov 04, 2010 | Samsung 225BW Monitor
Monitor will not come on. Power light just flashes.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Aug 13, 2010 | Samsung 225BW Monitor
Need to replace all capacitors in my 225BW. Need
The 225BW monitor uses the same capacitor kit that the 214T monitor uses. You can order the repair kit at:
http://www.ccl-la.com/LCDrepair4.htm The kits run $12 including shipping. If you don't want to do the repair we do offer a repair service for $30 plus shipping.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 31, 2010 | Samsung 225BW LCD Monitor
When turn on, get a picture for a fraction of a second then blank
you need your power supply repaired. you have bad capacitors.
Jan 01, 2010 | Samsung 225BW Monitor
NOT TURNING ON
The Samsung 225BW has a known issue with the backlight power supply going out. The dark screen with no power light or power light blinking are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide with pictures posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $30 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
Apr 05, 2009 | Samsung 225BW Monitor
Samsung model 225bw does not turn on
The Samsung 225BW has a known issue with the power supply going out. The dark screen with no power light or power light blinking are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide with pictures posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $30 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
Samsung 225bw display with NO VIDEO and flashing power button
A flashing power light and no picture is a sure indication of a shorted power supply board. There are parts called capacitors that fail and this causes the power supply to continuously shut down and restart over and over, hence the power light flashing. If you can do a little soldering then you can repair the unit. Here is a link to a service guide showing how to dis-assemble the monitor and repair the power supply board.
I hope this helps, if so please ratre my solution.
BuddyMc
Nov 22, 2008 | Samsung 225BW Monitor
Monitor
Steve from Monitor Technology. You need to open the monitor and locate the inverter board.
Remove 3 screws,turn the board over and locate 2 caps,C110 and C111.Replace,820UF/35V
this will fix this problem.
thewizguy@comcast.net
May 03, 2008 | Samsung 225BW Monitor
Samsung Syncmaster 275T Monitor Logo
401 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
