Question about Motorola Mobility RAZR V3x Cellular Phone
If I recieve call, I will not hear the phone ring on any setting --- phone will vibrate, notify tone sounds when I have a voicemail, audio plays when when I go to ringtone files.
  • temp_emailbo Jul 22, 2009
    I recently switched Carriers (I had Cingular) I'm not sure if it is gsm, but I'm sure I could call and find out. Could this feature be "locked"?
  • temp_emailbo Jul 23, 2009
Is it a gsm phone? or a metro phone that has esn# . i heard that people can hack and clone metro phones or on gsm phone super bluetooth hack another phone by borrowing your phone for a couple of min. and linking it hidden
Posted on Jul 22, 2009
No sounds ring tones
have you set ur phone to silent mode / vibrate mode. if not something is wrong may be a chip inside your phone which controls the audio is already busted.
Jun 04, 2013 | Cell Phones
When i recieve a text message there is no ring tone or vibrate
plz check your sound setting.for that
instructions are:
1. go to your phone's "setting".
2. enter into "sound".
3. "ok" or "click" on "vibrate".
4.and if you want ringtone at received time than go to "phone ringtone" below vibrate option.
Aug 17, 2012 | Samsung SGH Cell Phones
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
My phone will not ring out loud and vibrate at the same time.
To turn on a ringtone and vibration, go to your BlackBerry's sounds and ring tone options by either of the following ways:
1. Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
2. In the Home folder, go to your Options folder (usually toward the bottom, has a wrench icon) and select Sounds and Ring Tones.
Select the ring tone and volume that you want, and for Play Sound select Always. Scroll down to Vibration and set it for On.
There is an option for Vibrate with Ring Tone -- set that to on in order to make your phone both ring and vibrate at the same time, then save the settings when you cancel out, and you're all set.
Jun 21, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Double ring tone issue
Go to the same place that you go to to put it on vibrate and scroll down to set ring tones/alerts and sms text and change the settings the volume should be set to silent.
Apr 20, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Phone does not ring when call comes in on my Motarola Razrv3 cell phone. It vibrates but no ring. The ring volume is set on 7.
1st make sure that your phone speaker is not malfunction, to do this just play any ring tone from your phone to check whether there is a sound come out from the phone speaker.
If there is no problem to hear sound from phone then have to check the phone setting, to do this just PRESS and HOLD the button #, a shortcut to toggle between RING mode and VIBRATE mode. Or goto Setting>Audio>Style Detail, and change the alert type such as sound or music. Make sure u are not in the Silent style mode.
YBC (/\)
Oct 21, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
No Audio
dear,
check the backside speaker of ur phone. check it if ur main ear piece is working. means that u can listen a call.
because, music in this set, relates to the back side speaker.
Jul 10, 2008 | Sony Ericsson K510i Cellular Phone
No ring sound and music
at first you go the setting s in your mobile in there go for phone setting in that it given the default setting select it after one min you swicth off your mobile and swicth on the mobile you got the ring tone in your mobile
May 30, 2008 | Nokia 6111 Cellular Phone
Motorola Mobility RAZR V3x Cellular Phone Logo
89 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
