Question about Frigidaire Washing Machines
Won't spin fast, will spin slow - Frigidaire Washing Machines
  • 520 Answers
First I would check the belt. Make sure it has good tension and looks ok. No visible damage or anything. If the belt is ok then have the clutch replaced. This is usually the culprit. Once the clutch wears down to a point it can't maintain enough pressure to spin at full speed and begins to slip. This is why it only spins slowly. The whole thing shouldn't cost more than about $150 or so. Hope this helps. Good luck.
Posted on Jul 22, 2009
I have a front loader washer Kenmore Elite Model #796.40311900 that spins SLOW, not FAST as it should on spin. The digital readout works normally.
sounds like maybe drain filter is plugged and unit is not draining fast enough. if you have drain access in front pull it out and clean it.
May 08, 2017 | Kenmore Washing Machines
My washer is stuck in fast speed. Can't make it agitate in slow speed. Model # 110 26892690 .
I assume you mean spin.You should have a slow/half spin selection on your machine if not select a delicates or wool program this will give you a slow spin.
Feb 24, 2015 | Washing Machines
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
Atf6000fs2 does not fast spin to remove water only slow spin /checked it on all spin speeds
Either the motor cannot turn over fast enough to power the pulley system, or there is an issue with the pulley system.
Sep 04, 2012 | Frigidaire Affinity ATF6000F Front Load...
What would cause 2.7 motor to shut down and won't
did the timing belt let go?sounds like it
May 12, 2012 | 2001 Chrysler Sebring
My coffee grinder won't spin slowly
now is it working on slow or it going to fast ,as you have made two postings ,and both contrary so if its playing up then buy a new one as its cheaper than a repair .
Nov 12, 2011 | Coffee Makers & Espresso Machines
Washer spins but really really slow, not fast enough to extract water
it can be the pump if it does not get the water out fast it will slow spin best way to check put it on spin with nothing in and watch it if it does the same then the moter is faulty change it try ebay for replacements
Jul 28, 2009 | Speed Queen ATS90AWN Front Load Washer
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Washer won't spin fast, only slow
tyr removing the lower acees panel from the uint , ther is a "button trap" located there to catch debris from entering pump assy, chances are its clogged and if it cant drain all the water it wont go into high speed spin, also you MUST use an HE detergent. HE detergent specifically designed for front loading washers
Apr 28, 2008 | Kenmore 44102 Front Load Washer
Washing Machines Logo
42 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
