Question about VinoTemp (VT60GNV) Wine Cooler
Vinotemp 2 zone wine cooler flashes "Lo" on numeric display for lower compartment - will not hold temperature requested. Temp in upper compartment will not go below 67 even though it is set for 51. Room temp is 76.
    Problem Solver:
  • 8 Answers
Not sure, but did you clean the filter in the back? Ours has that, and the temp starts creeping up every few weeks until I clean it. But we've never been able to get it below 58 or so, and in the last year, not below 60. I think that's just the nature of this type of cooling. Our house is also at 80. But, can keep it at 60 with the above cleaning.
Posted on Sep 17, 2009
  • 27 Answers
SOURCE: wine cooler
cheak the machine main on/off switch, cheak the in$out phase line
Posted on Jun 21, 2008
  • 16 Answers
SOURCE: vinotemp wine cooler is squealing
fan motor needs replaced
Posted on Sep 08, 2009
  • 14 Answers
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
Posted on Sep 21, 2009
  • 14 Answers
SOURCE: Is this real?
Service @ Vinotemp 800-777-8466
Posted on Sep 25, 2009
  • 5 Answers
SOURCE: Magic Chef Wine Cooler Model MCWC44DZ Where can I
On the Magic Chef site you can order parts for the cooler. I took mine out and treid to find them on the web somewhere else and could not locate them anywhere except China and England. I know this isn't true but tried every search option I could think of. They are about $22 plus shipping (HIGH). You might try the following: http://www.fixya.com/support/t1814377-magic_chef_mcwc44dz_e4_error
Posted on May 17, 2010
Just purchased and is not cooling at all
please see this steps and fix it. God bless you
1. Unit not running
Possible Causes Response a. Power cord unplugged
b. No power at all
c. If display lighting, temp setting high
d. If temp setting ok, sensors or control board bad
e. Compressor unit malfunctioning a. Check for power cord plug
b. Check receptacle voltage & fuses
c. Lower temperature setting
d. Call service for replacing sensors or control board
e. Call service for component check
Nov 27, 2013 | EdgeStar CWR361FD - 36 Bottle Built-In...
I purchased a 52 bottle kitchen aid wine cooler. No matter where I set the thermostat, it is always 45 degrees and readouts are sideways "T's" instead of numbers.
You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. arrow_results_summary.gif Get Adobe Acrobat Reader Click Here=> KUWA244PBS Parts List
and here=> KUWA244PBS User and Care Guide
If you should need the service manual you will need to cant me here=> HERE Reason is Whirlpool does not allow me to publish the SM here.
The beverage center and wine cellars have a temperature display for each zone. 12 volts
AC is supplied to the display board from a transformer in the unit compartment. The displays are only temperature displays and have nothing to do with any cooling function. A thermistor is used to sense temperature for each zone. The thermistor for the bottom zone is located inside the lower portion of the separator. The thermistor for the top zone on the wine cellar, (mid zone on beverage
center), is located in the upper portion of the separator. The thermistor for the beverage center upper zone is located on the inside of the 2-piece evaporator cover. It is on the right-hand side.
The mid temperature for the bottom zones on either unit are 60? Fahrenheit plus or minus 5 degrees. The mid temperature for the mid zone on the beverage center and the top zone
on the wine cellar is 45? Fahrenheit plus or minus 5 degrees. The mid temperature for the
top zone on the beverage center is 38? Fahrenheit plus or minus 5 degrees. I think at tis time you should check each section with a pocket size digital thermometer to cofirm tha the mechanical thermostat is within calibration. Click Here=> 4344690 Temperature Control
Click here for a=> KUWA244PBS Beverage Center Wiring Diagram
I believe the problem may be in the PCB transformer shown at the bottom right corner of the wiring diagram. It is possible o change the transformer but I have not been able to find the board that powers the LED temperature readouts. If needed let me know and I will call Whirlpool mfor you, Thanks, Sea Breeze
Oct 09, 2011 | KitchenAid KUWA244PBS Wine Cooler
Upper & lower level does not cool. Temperature stays at 78 for lower level & 75 for upper. In attempting to set cooler temperature at 55 for top and 45 for lower it immediately reverts back to 78...
take shelves off. temp display unit in middle of shelf is where circuit board is for testing. pull middle unit forward and unscrew back panel. check lines for leak. color should look like a teal green. thats where your leak will be. Need tech. for the rest.......good luck!!!!
Jun 02, 2011 | Danby DWC283BLS Wine Cooler
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
MC wine cooler MCWC44DZ error code e3
I had an E3 on the upper zone. This fix was simple. Unscrew the 2 screws for the middle tray. Pull tray out as far as you can. Check the wires in the back, those are the wires for the fans in the back. The connectors over time corrode, and break off... All I did was connected the 2 wires that had broken off of their connector directly to eachother. E3 went away and the cooler is working as it should now.in
Jan 04, 2009 | Refrigerators
Three Temperature zones
Did you read the owners manual? It will be kind of hard to tell you because there are so many different settings for different areas.
Dec 26, 2007 | Danby DWC310BL Wine Cooler
VinoTemp (VT60GNV) Wine Cooler Logo
395 people viewed this question
Top VinoTemp Furniture Experts
Dan Webster
Dan Webster
jackj59
Level 1 Expert
jasbo
jasbo
Are you a VinoTemp Furniture Expert? Answer questions, earn points and help others
