SOURCE: my honda sputters out and dies after 8-10 miles
Could be Lots of things Causeing that Frist Could be a Cracked Spark plug and Be your Timing out on it also could be Vacume Leack EGR stuck open or Closed Bad Wires Emissions Control System not workin Right
SOURCE: will start & drive but after driveing it will sputter & die ?
Check the small ground wire from the engine to the body chassis. Remove it from both ends wire brush were the lugs connect also wire brush the lugs. Install some vaseline on the connection points and tighten.
SOURCE: Vehicle dies while driving down the road.
could it be the A/C pump kicking in. might be boging down the motor or electrical circuit, not letting the injectors get enough power. This could happen if the bearings are going bad in th A/C pump or there is a short in it. Just an idea. sounds like you have done the main components.
SOURCE: engine died & wont start no spark ignition coil tested good
try your ignition module in the distributor much more likely. just install rebuilt distributor if that is the problem , if you just replace module the main distributor assem will **** out shortly after.
Make sure you check for broken timing belt also it is one of those two!
