Question about Oreck XL Ultra Bagged Upright Vacuum
Oreck xl 9100 bag wont stay on using type cc replaced inside bag hanger
    Sergeant:
  • 206 Answers
What year model?
Pre-late 1990s, bag on upright just fit over the adapter in the tube.
Lat 1990s, went to a version that had a sliding piece of paper to cloe off the bag & prevent spillage, and required a hinged plastic piece for chipboard piece on bag to slide into.
Must have right bag for the unit, otherwise it will not stay on, will leak.
Posted on Jul 30, 2009
Can I use PK8000 vacuum bags on XL oreck w/dock that calls for CC bags
no. they do not have the hole at the bottom to fit into the bag dock properly and you will risk getting debris all inside of your outer bag
Jan 06, 2017 | Oreck Vacuums
What bag for oreck xl 2310rs?
Depends on whether you have a bag dock or not. Also would depend on whether you want a cloth disposable bag that will filter out things like pet odors or smoke and things like that, or go with a cheaper option of paper bags. If you have the bag dock, you will need the"CC" type bag.
Jul 07, 2014 | Oreck XL Ultra Bagged Upright Vacuum
How to tighten Oreck XL upright position to stay upright
The detent that is mounted to the inside of the housing is probably broken off and the only way to get that fixed is to replace the housing. If you have been getting regular tune ups at a service center there may be the possibility of getting that done under warranty depending on how old your vacuum is and how long the warranty period is for that vacuum.
Jul 05, 2014 | Oreck XL Ultra Bagged Upright Vacuum
How to keep my oreck xl bag docking station attached. bought
Put smaller part of bag docking system on first. Seperate it from the other. It has to be pushed on past plastic lip around hole. It should feel very tight. Then attach larger part of bag dock onto the smaller one.
Jun 13, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Schematic for xl 9100
A quick three second google search turned up
http://www.vacpartswarehouse.com/Oreck-XL9100HG-s/2927.htm Vac Parts Warehouse
Jan 24, 2014 | Oreck XL21 Bagged Upright Vacuum
I cannot keep the bag attached to the handle inside the cover on my Oreck XL Vaccuum. When it comes off dust blows out into the cover instead of the bag which makes it very hard to unzip the cover.
there should be a spring ring that slides up over the bag on the handle if thats missing try and use a couple of heavy duty rubber bands. however i do suggest you order the correct part.
Feb 13, 2013 | Oreck XL Ultra Bagged Upright Vacuum
Oreck vacuum is clogged in tube
Snake it out with a wire hanger
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Jan 04, 2013 | Oreck XL Ultra Bagged Upright Vacuum
I have an Oreck XL 2310RS. What bag number do I need for it? Thanks.
All oreck uprights take bag type CC. I would Recommend buying oreck brand bags. they have the only patton on the bags. off brand bags will work but they will leak and tear and break.
Sep 08, 2011 | Oreck XL Ultra Bagged Upright Vacuum
Having a terrible time keeping the bag attached during use. I am tired of cleaning the inside of the cloth zippered bag. I am using the correct Oreck vaccum bags, and using the metal clip that holds the...
I would Recommend getting a docking system. its $20 and takes place of the metal clip and ensures that the paper bag and outer bag both stay in place and to ensure no leakage.
Sep 04, 2011 | Oreck XL Ultra Bagged Upright Vacuum
Oreck xl 9100 how to replace the fan
I just replaced the fan (plastic) on an XL9100. I assume you got the bottom plate off (5 screws).
Undo the single screw holding the suction housing in place.
Remove the two screws holding the motor in place and gently lift the assemble up, being careful not to stress the wires. The motor and fan assembly should now be exposed. If the nut holdling fan in place is removed, the whole fan should slide right off. If it does not, try a little WD-40 on the shaft and wiggle and move from side to side. (I slipped a small drill bit between the motor fan (motor cooling fan) to prevent the shaft from turning when you remove the nut.) Be sure you turn the nut counter-clockwise to remove it.
You should now have the fan off. Reverse the procedure to place the new fan - following the directions carefully as some assemblies need a washer and "feathered" washer on the top.
Assuming everything went well, it should work.
My 9100 sucked a magnetic bearing and trashed the metal fan to where suction was weak. The new fan works great.
Cheers
Mar 26, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL Ultra Bagged Upright Vacuum Logo
941 people viewed this question
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
