Question about Megatronix - PASSLOCK-SL2 - GM Passlock Data Bypass Kit - Self Learning Byp
Keys stuck in ignition of 73 chevy caprice
I have a 1973 Chevy Caprice. One day after arriving home, i tried to turn the car off and the key wouldn't turn back to the off position. . . and the car kept running. I had to disconnect my distributer and batteries to get the car to turn off. Now the key will not come out of the ignition or turn to the off position. HELP. . .!
  • 61 Answers
Spray a generous amount of wd40 or similar penetrating lubricant into the ignition cylinder. now take a hammer and tap the back of the key (not too hard, but be convincing) continue alternating between spraying and tapping until the key turns.
Posted on Jul 24, 2009
I have a 1994 caprice,the ignition is stuck in
No.
It could be a damaged lock cylinder, or the ignition switch.
You can disconnect the switch to see if the lock will move.
Aug 29, 2013 | Chevrolet Caprice Cars & Trucks
2000 Chevy Lumina wouldn't start at gas station out of nowhere...security light and volt light came on.
to reset security you'll ned to do the 10min key with ign. on for 3times after each 10 min turn key off briefly then back on without trying to restart after 30min or three 10min ign on cycles turn off key briefly then the car should start
Sep 02, 2012 | 2000 Chevrolet Lumina
93 chevy caprice classic fuel pump relay
i would think if it were the relay you wouldn't hear the pump come on. I would unhook the fuel line just past the fuel filter. turn the key on long enough to see if the pump is pumping and is it getting past the filter. if it is you can rule out a possible clogged filter and you know the pump is pumping. I would then start looking for a clog. or locate the relay take it to the part store and get a new one. the problem is the relay only relays electrical signal to the pump that turns it on and off etc it doesn't tell it to pump or not pump gas so if you can hear it running it's not the relay
Jul 17, 2012 | Chevrolet Cars & Trucks
Have a 1995 Chevy Caprice classic won't start get light that says pass key fault
Get a second ignition key, the one you are using is dirty or moisted, you need to turn on and off the car witha clean key, hapens to me once in a while.!!
Jun 24, 2012 | 1995 Chevrolet Caprice Classic
My 96 chevy caprice with lt1 wont start turn over
i have a 1996 chevy caprice LT1 that wont start due to hurricane sandy the water line of the car was half of the bottom pully which i think the starter got wet when i returned back to the car i turned the key it didnt turn over but i had power is there any solutions please help
Apr 28, 2012 | 1996 Chevrolet Caprice
2004 Sante fe 3.5L 2WD went out to go to work and wouldn't turn over, (assumed dead battery), went down and got new battery and installed, still wouldn't turn over, (assumed starter shot),removed...
TEST POWER LEADS TO STARTER FOR POWER
AT STARTER (BATTERY POSITIVE TO STARTER BATTERY NEGATIVE TO ENGINE BLOCK)
THEN TEST FOR SIGNAL POWER TO SELENOIDE ON STARTER
(KEY TURNED TO START POWER SHOULD GO TO SELENOIDE)
IF NO POWER TO SIGNAL WIRE CHECK FUSES AND RELAYS
ON STARTER CIRCUIT
IF THIS CHECKS OUT MAY BE AUTO TRANSMISSION NUTRAL PARK SWITCH
TRY TO START IN NUTRAL OR WHILE SHIFTING TRUE GEARS SLOWLY WITH SHIFTER
IF STANDARED CHECK NUTRAL SAFETY SWITCH
May 08, 2011 | 2004 Hyundai Santa Fe
How do I replace a key ignition to a 89 chevy caprice
need special tools like steering wheel puller and a lock plate compressor.
Feb 25, 2011 | 1989 Chevrolet Caprice
My oil light came on my chevy caprice and a few days after i changed it and the car stop running i followed the manual and it said to pump the acell 3 times to restart the system but no good
Did you have the key turn to the on postion? press the gas pedal 3 times and this should reset the oil light, do you have any other problems with the battery or anything.
Apr 24, 2010 | 1994 Chevrolet Caprice Classic
Engine is suddenly getting no fuel. Turns over great. There is plenty of gas in the tank. It wouldn't run after driving around two days ago, then it ran all day yesterday all day yesterday, then after we...
Could be the fuel pump. Try hitting the bottom of the fuel tank a few times while someone try's to start it, if it starts then the pump is on it's way out.
Aug 02, 2009 | 1992 Chevrolet Caprice
Megatronix - PASSLOCK-SL2 - GM Passlock Data Bypass Kit - Self Learning Byp Logo
234 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
