SOURCE: nintendo ds lite will not turn on, when trying to charge the orange lite blinks once.
after researching this for a while, i heard that it is because the fuses have blown inside the ds. you can try to fix it but it is risky.
good luck!
SOURCE: Inspiron 1200 battery light continually flashing orange
If your battery LED flashes or is solid Yellow or Amber color, this usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
SOURCE: orange blinking power light on inspiron laptop
I recommend purchasing a new Dell Inspiron battery.
The code 4 blinking orange or amber and one green, means a defective battery.
Thank You,
Raphael
SOURCE: dell inspiron blinking orange battery light. keybrd not respondg
Try this: remove your battery, unplug power, press and hold power button for at least 20 seconds, plug power cord back in but not the battery, press power and see if you get normal boot. If this is the case, your battery probably needs replaced.
SOURCE: Dell Mini Inspiron 910 battery
Please refer to the following 2 articles to diagnose & fix your problem:
http://www.fixya.com/support/r6416355-troubleshooting_laptop_battery_problems
http://www.fixya.com/support/r6416948-troubleshooting_laptop_power_failures
