Question about Kitchen Appliances - Others
Leaking condenser?
  • 201 Answers
Yes
Posted on Jul 22, 2009
Can ac condensor leak water on ss cobalt at bottom of pass side or could it be radiator leaks in front of duel fans
The a/c condenser doesn't leak water, but it certainly condenses the moisture out of the air (hence the name). The HVAC box is supposed to have a drain installed at the bottom to allow the condensation to run out (usually via a hose through the firewall). If this drain is blocked, the condensation will accumulate and leak into the passenger compartment.
Apr 17, 2018 | AC Cars & Trucks
Furnace has water under it, why? Its a Dayton gas furnace.
There are several questions that need to be answered about what type of system you have, but i found this posting that may help:
As your gas furnace runs, is there water leaking at the base? Is the furnace's air filter wet, too?There are a few things that could be happening here. But if you have a high-efficiency furnace, here's the most common cause: a condensation leak.
We'll explain why a furnace creates condensation, and what's causing it to leak out of your furnace.
Note: You'll know if you have a high-efficiency furnace if:
  • The yellow energy guide tag says your furnace's efficiency is 90% or higher AFUE.
  • The vent/flue pipe is white PVC as opposed to metal.
Why a high-efficiency furnace creates condensation
How in the heck does a high efficiency furnace create condensation/water anyway?
It's all about how the furnace extracts heat from combustion gases.
A lower-efficiency furnace extracts some heat from combustion gases and then quickly vents them out the flue pipe.
But a high-efficiency furnace, to extract more heat, has 2 heat exchangers. These allow the furnace to extract heat from the gases for a longer period of time. This causes the combustion gases to cool and then condense.
That condensation then exits out your home through a drain. But if that water is pooling around the furnace, there's a problem preventing it from draining properly.
Causes of a condensation leak around a high-efficiency furnace
  • Clogged condensation tubing
  • Clogged condensation drain
  • Breaks in the condensation line
  • Issues with the condensate pump (if you have one)
You'll need a furnace technician to diagnose which of these is the issue and then fix it.
Other causes of leaking water around a furnace
If you have a conventional, standard-efficiency furnace...then its flue pipe may be incorrectly sized.
If you have a whole-house humidifier connected to the furnace...there may be an issue which is causing the humidifier to leak into your furnace. Your humidifier should be getting annual maintenance from a professional to prevent this.
Dec 13, 2016 | Dayton Heating & Cooling
2005 Chrysler Town and Country Coolant Leak After running Air Conditioning?
You do not say if you are losing coolant or not , if not every thing is ok as its condensation from the air con, If it has coolant loss it could be over heating, make sure the extra fan comes on with the air con.
Aug 20, 2014 | Vehicle Parts & Accessories
Water is leaking from a seam on my muffler 98 jeep
condensation is a common occurance in all vehicle exhausts. Your muffler is leaking in the seam which indicates that it may need replacement. Condensation will then be seen leaking form the tailpipe only. Generally, the heat of a warm car dries up this condensation. Short runs do not allow the car to fully warm up. Excessive short runs causes abnormal condensation buildup. Water inside your muffler will eventually rust it and thios is most likely why you see a leak in the seam in the first place.
Sep 21, 2012 | Jeep Grand Cherokee Cars & Trucks
A/C coolant from condenser
First of all, refridgerant is a gas. All AC systems leak water due to the condensation from the ice cold pipes meeting the hot ambient temps. Look around at most other cars in parking lots, anyone using they're ac will have a puddle. Get other opinions before you act.
Aug 08, 2012 | 2002 Pontiac Montana
Our A/C unit when running, the drain water isn now backing up and leaking over the side in our basement. we've never had this problem before.
Hello, this usually indicates a clogged condensate line or cracked condensate pan. Try using a wet/dry by attaching one end of it to the otlet of the comdensate line, the suction pressure should dislodge the clog. If the line appears clean the the pan is cracked and will require a technician to come out and fix it.
Sep 06, 2011 | Goodman CKL36AR36 Air Conditioner
New inverter reverse cycle leaking water out the front of the unit. Its 44 degress outside, could this be the problem?
Is it leaking out of the evaporator(inside unit) or condenser?
If it is leaking from the outside unit on defrost then it is normal, if it is leaking from the inside unit then you have a blocked condensate drain tube!
These units defrost from time to time and is normal, it is actually melting the ice that can form on the condenser when it is cold enough outside, it has to initiate a defrost cycle so that air can flow through the condenser again after the cycle is complete.
Then it will return to normal heat pump mode, this is assuming that you have a heat pump.
Jan 11, 2010 | Fujitsu Electronics - Others
What is the white part that holds water tubing on back of Amana refrigerator? It is leaking water around the tubing
hi,
tubing at the back refrigerator is the condenser, function of this is heat rejection that absorb from your evaporator inside your refrigerator,the white part of holding tube condenser is tube holder mounted by screw to hold condnser tubing has no relate inr efrigetration cycle.the screw use on tube holder was directly pin at the back side of eveporator where cooling effect emerge some ice melted or defrosted form water pass through on screw tube holder,you can fix loosen screw have some sealant pathced to hole where srcew located after a minute of drying time screw it again so that water leak may not come out to that tube holder through your condenser,
well,if that leak does not harm or not make any trouble passing through your condenser its still good condenser need to be cooled so that refrigerant inside tube can flow on liguid state effeciently.on large refrigeration such as ice plant
condenser was designed to have a water shower on tube called evaporative system.it make coole the condenser tube.
this ideas can give you clear explanation why water leaking on tube condenser.have anice day rate me,thanks a lot
May 04, 2009 | Refrigerators
Water leaking underneath when drying,whats the problem
Hello!
If leaks only on drying, then it might be the condensing system, maybe the fittings of the condenser on the drum got loosed. Remove the back panel and inspect after leaks on the left side where the condenser is.
Feb 27, 2018 | Washing Machines
Kitchen Appliances - Others Logo
80 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
