My seting is desabl my display touch not working.i am chang the hard disk ,but display touch no working.so pleas send me a slosion.
SOURCE: U7-45 xerox dc 440st
On the Xerox 44st a U7-45 is a ITT/IPS DCSYS Comminication Interface Error. One might recheck the copy cartridge to see if it enters in correctly. The latch needs to snap close, not just partilaly closed. The plug at the back of the cartridge and on the main wall needs to be seated in correctly so the cartridge does connect to the plug on the main wall at the back of the machine.
The side door needs to be closed correctly. The machine has a lever at the back corner of the door, it actuates a switch on the inside back.
This also can be linked to a board not working well. Without seeing the machine, there can be many small complicated items that can cause this problem.
Sometimes ESS software needs to be reloaded, and can only be done by the service representative. This is even more so if the messege says "Non-Compatible Cartridge." In this care there is nothing one can do to repair the machine, but to place a service call.
Good luck.
SOURCE: can you pleas send me a pic of the timing belt
Welcome to FIxYa.com Regards, Lee Davidian A Four Thumbs up ^^^^ is appreciated for answering your
question. And please take the time to rate me by leaving a testimony. Thank you, Lee Davidian
SOURCE: verbatim hard disk250gb(model#47562) pleas give me
I formatted my drive on windows 7 and it went from fat32 to ntfs and i want it back to fat32, how do i do that. it says that the volume is to big?
SOURCE: touch desabled
hi
try to make hard reset to the phone
if not maby you need to replace the screen
http://www.rylwy.com/
