Question about Music
One key sound louder and does not respond when I
BERINGER Concert CDP1000-BK Piano: one key sound louder and does not respond when I press it softly. Can I order an individual key and replace it?
    Novelist:
  • 133 Answers
Keyboards that sense the dynamics of playing have two contacts underneath each key. One of those contacts is most probably a bit dirty.
To clean it, you need to open the piano housing, remove the faulty key (you may need to release the keyboard from the base), there are rubber (or another kind of) contacts, similar to those in a remote control. If they are rubber contacts, you need to clean them on the rubber side as well as the tabs on the board under the rubber button with a cotton stick and some ethyl or isopropyl alcohol (don't use acetone, benzene or similar strong solvents, you will damage the rubber).
If they are another kind of contacts (e.g. relay type - metallic, you need to clean them with very fine sandpaper.
That should do the trick, but if it doesn't, there is probably physical damage to the conductive rubber or tabs on the contact board. To repair the rubber contact itself you need repair liquid (e.g. for remote keys, which is actually made of some benzene, some rubber glue and some grapphite powder). You can make it yourself but you may need to experiment with the grapphite/glue ratio to get enough conductance for the contact to work properly. You'll get the grapphite dust by smearing a drawing pencil core over a piece of fine sandpaper.
If the contact tabs on the board are damaged, you'll need some "leitsiberlack" - silver repair liquid, this is a similar liquid that contains silver and makes a somewhat solid contact. (i'm not sure about sources for this, but in europe, it's sold by Conrad electronics under the name "leitsilberlack"). You need to apply some but take care not to connect the two halves of the tab or the key will not work properly.
I had a case of identical malfunction on a roland synth (it has rubber contacts) and the cleaning alone solved the problem entirely, hope you can solve it that way yourself.
regards
3rq8 (Triarcuate)
Posted on Jul 23, 2009
QS8 keyboard. Why is volume in organ mode much louder than piano mode when I switch between modes without touching volume slide?
On organ mode, in general, almost all brands of the modern keyboard, velocity setting is not enabled. Setting velocity is used to determine how much the level of the sound that follows how strongly you press the keys. It is really just to imitate the sound of vintage organs, which in the past, electronic organ technologi not use the velocity on the keys. So, how strong / slow we press the keys, the sound level will remain the same.
At the Piano mode,modern keyboard using setting velocity. This also to imitate an acoustic piano, which, if we press the keys slowly, the sound level will be slow as well, and vice versa.
So, in your case,at the same volume slider, try to play on the organ modes, note level. Moving to the piano mode and press the keys securely powered (full power). Then the sound level should be equal to the organ mode.
On modern keyboards, also included organ sound that added velocity setting. Usually found on the user bank.
Sep 01, 2015 | Alesis Music
Alesis QS8 keyboard. The volume of the organ is much louder than the keyboard when I switch between both modes without touching the volume slide. How can I fix this.
Why do one piano key , when hit, sound louder than other keys ?
I am not an expert but with the little knowledge I have I would suggest the following.
Check the 'Throw' on the hammer, is throwing the same distance as all the other hammers.
Check the felt dampening, this usually moves when you press one of the pedals. Is the felt different to the other keys.
A lot also depends on which string it is, top end or bass. The string could be past it's sell by date and causing the problem.
Hope this helps in some small way.
Regards
Sep 29, 2014 | Music
Crackling speaker as soon as i switch on my digital piano
It looks like the Korg c-15s has a internally mounted speaker and so I will assume that the speaker and amplifier are part of the piano base. It sounds like either the speaker is blown (crackling sounds heard as deformed voice coil scrapes the magnet structure) or the audio amplifier is distorting the audio.
Connect the piano's output to an external amplifier and speaker to properly identify problem.
Oct 17, 2012 | Korg Music
Volume on the piano is less than half the volume it should be. Demo and play along songs play at full volume but keyboard wont no matter how hard the key is pressed, Is there a fix for this...
Pianos do NOT respond to keys pressed hard... they respond to FAST presses. If you have an issue with the piano, first go on record to activate your warranty. Most of these electronics DO have a setting that adjusts the "feel" which affects the loudness versus key velocity... Now here is a secret??? Shh... The manufacturers turn up the demos just like the advertisers turn up the commercials on the TV... I would suggest looking for the adjustment of feel, and if that doesn't get satisfactory results, find another and compare yours to another... if yours is still underperforming, exercise your warranty for repair or replacement.
Jun 11, 2011 | Williams Encore Digital Piano
Hi there, I have a Nord Stage EX 76 and played a gig on friday night outdoors. I have set the keyboard up and now one or two of the notes occasionally sound much louder than they should. The problem...
What has happened is that one of the contacts on those notes is not working properly. Each key has two contacts. One makes before the other as the key is pressed. The processor MEASURES the time between those as you hit the key to read the VELOCITY you have hit the key with. This velocity is often used for loudness on many voices such as the piano. These contacts are USUALLY conductive rubber pills suspended in silicone rubber "domes". One can disassemble the key area and clean BOTH the black rubber pills and the circuit traces they are pressed against using Q Tips and ONLY 99% isoprophyl alcohol to restore proper operation
One needs to be very careful when disassembling unit as there are many tender ribbon cables and connectors. Best to have clear work area and two people to "control" the halves of the shell while opening..
Nov 07, 2010 | Clavia Nord Stage 88 - Digital Stage Piano...
Electric piano has key sensitivity problem
The key contacts have gotten dirty. They are often a conductive rubber pill that is pressed onto a circuit board. There are two pills per key and the difference in time of those contacting measures the velocity and the loudness for a piano voicing.
The contacts need to be cleaned with 99% isoprophyl alcohol and a Q-Tip. Use NO other solvent. Clean all contacts while the unit is open.
GREAT care must be taken with cables to avoid damage.
You did not specify your brand or model, but unless you are electronically adept, you should take it to a shop for repair.
Jan 26, 2010 | Music
Kurzweil digital piano unpredictable voices and volume
The contacts of various switches and keys are likely dirty. They are often conductive rubber and need cleaning with 99% isoprophly alcohol and q-tip. Clean both the conductive rubber pill and th circuit board traces they contact.
Sep 17, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Korg C-15 S concert piano
ik heb 20 jaar geleden een korg c 15 piano gekocht voor 5000 nederlandse guldens.
we zijn tot nu toe nog steeds tevreden met de piano.
sinds een paar dagen wil hij niet meer hard spelen ,je hoort hem alleen nog maar in de verte .
alles is goed aangesloten ,schuifje staat op zijn hardst en er staat ook stroom op ,want het lichtje brand .
kan iemand mij vertellen wat ik daar aan kan doen ,ik wil hem nog niet kwijt ,misschien is het maar een kleinigheid.
vriendelijke groet
mevr v haasteren
Aug 24, 2009 | Yamaha Full-Size Keyboard
Manuals for Concert Piano Korg C-15
I have a Korg Concert Piano (C-15S) which was working perfectly till about two months ago. I have been on vacation for two months, had left the piano unplugged from the electric supply point, but on re-connecting now, I get no sound from it. Is there a reset button (or other device) that I may have to use? Appreciate your advice.
Thank you,
L. Paul
Apr 03, 2009 | Yamaha Full-Size Keyboard
Music Logo
197 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
