I tried to resolve by reset the error code but still cannot solve.. pls help
SOURCE: Canon ip1000
I'm not sure about this cuz I could not find anything on the error code of 5000 for the IP1000. But if it is waste pad if full, then try out this website.
http://forum.eserviceinfo.com/viewtopic.php?t=5921
Hope this is of help.
SOURCE: How to Solve Error code SC496 for Aficio 551
hello Sir; You have to empty the waste toner bottle it located right hand side bottom, open the doorlook at "A" area you will see a big narrow plastic bottle pull out a black buckle slide out the bottle, dump the toner,the code will be disappear!
SOURCE: Brother MFC 8220 Error code 71
that code indicates that your laser unit has gone bad. no way to reset or repair without a tech replacing the laser unit itself.
razors
SOURCE: i forgot the lock code of my n73 cellphone
Visit http://www.unlock-free.com/nokia/
or
http://www.unlock-free.com/nokia-master/
And follow the site instructions.
Rate this please.
SOURCE: Can you tell me what
hi
regarding your error go to following link
http://www.copytechnet.com/forums/xerox/36062-xerox-docucentre-ii-2055-error-016-315-a.html
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
