Converting from 220 to 110 volts
Most brands of air comperssors are built to work on either 220 or 110 v. I believe that 220 v compressors are more efficient and draw less current and run cooler.
The more expensive compressors have a switch allowing for voltage selection. Still others will have a wiring diagram printed on the motor allowing voltage change by changing jumpers. Most all of the sears compressors that I have repaired were of single voltage with no other way to change except change motor. Do not worry however, you have the better motor. It is easier to convert the outlet plug to 220 by isolating the circuit and installing a 220 v breaker. enjoy
