SOURCE: Transmission on snow blower-sears
most snow blowers are belt driven instead of hydraulic drive. it sound like the belt needs replaced.
SOURCE: snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
SOURCE: Looking for a Free PDF manual for Mastercraft Snow
Your snow blower was made by MTD. You can go to outdoordistributors.com/mtddoor.htm. Put in the model 319-586-515, This site will bring up a parts list and diagrams. Some are not an exact match to your model but I believe it will help with what you are looking for.
Good Day.
SOURCE: My toro 1128 OE snow blower wont throw snow the
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
SOURCE: snow blower auger keeps running when not
sounds like the tension adjustment is tight or sticking check for proper tension and that the action is not froze up
