Question about Toro Lawn Mower With Toro Power Tools
I just changed the spark plug and the mower doesn't seem to want to fire... ANY HELP!!
  • Dan Todd May 11, 2010
    Did you make certain you used the same type plug you took out? Did you check the gap in the electrode? Did you make sure the clip inside the rubber head that goes onto the sparkplug is snapped on all the way?
    Scholar:
  • 71 Answers
Did it run fine before you changed it? Did you tighten it in all the way? Did you make sure the plug wire was plugged in all of the way on the top of the plug? Sometimes the rubber boot fits so tight that you think the connector is touching and it's not.
Posted on Jul 23, 2009
Have Lawnboy Kohler 149cc smart choke 6.5ft lbs engine bought last year won't start doesn't seem to be firing?
REMOVE THE SPARK PLUG, RECONNECT THE CABLE AND WHILE THE SPARK PLUG IS RESTING ON THE BLOC OPERATE THE STARTING PROCEDURE AND SEE IF THE PLUG IS SPARKING.
May 09, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
I have a John Deere La115 that stopped running, I checked the plug, blew out the fuel lines and there is gas in the filter but does not seem to be getting to the carb. How can I figure out if it is th
if it doesn't fire on starting fluid then you have a spark problem unplug the engine connector and recheck for spark if you then have spark check your safety switches if still no spark check the coil
Jun 06, 2012 | Garden
We have a murray riding lawn mower 287707 it turns over and it wont start. Spark plug new and it sparks and just changed oil, cleaned carbuator, new fuel line and new air filter we tried everything. Can...
on the bottom of the carb there is a solenoid if that solenoid doesn't have power it shuts it off a bad safety switch will cause it to not have power if so start with the clutch/brake switch
Jun 03, 2012 | Briggs & Stratton Garden
Mtd yard tractor will turn over will not start
if it doesn't fire with starting fluid then there is a problem with spark unplug the connector at the engine and try starting fluid again if it fires with the small connector unplugged the it could be a safety switch if no then pull the cover off the top of the engine and check the coil
May 20, 2012 | Garden
Has a mist in motor
A miss or mist? If it is mist, possibly radiator hose, heater hose, oil sending unit. What kind of fluid is it? If it is a miss then first thing would be change the spark plugs if they haven't been changed in a while. If it keeps missing after that try pulling the spark plug wires one at a time with some spark plug wire pliers. If you pull one and it doesn't make a difference then that is the cylinder that isn't working. Put a spark plug in that wire and see if it is firing by grounding the base of spark plug and watching it. If it doesn't fire first try putting on a spark plug wire, if that doesn't fix it, you must have a bad coil pack. If you have spark when doing the test above then maybe an injector that isn't working. Please rate my answer so I am rewarded points for it.
Feb 01, 2012 | Cars & Trucks
Mower will not start, seems to be ignition problem, engine doesn't even try to fire. checked spark plug and gap, checked ignition switch wire and changed coil pack.
Remember, if all of the safety interlocks aren't "made", the ignition circuit will never "close".
The symptom will be not even trying to turn over.
Gary
Jun 27, 2011 | Garden
Have a fh541v engine on a wright stander mower,one of the cylinder seems not to be fireing. I'v got gas and spark ? I've got compresion, value's are opening, take off plug wire no change, take off other...
my guess is the guide rods are bent . check and see if the valves are closing all the way. i just experienced the same problem on my mower
Aug 02, 2009 | Garden
Have 2 craftsman riding mowers 42"cut one 16,50 kohler engine/the other 17hp. both have the same symptoms won't start tried plugs primed cylinders with starter fluid also gas, seems like they have no spark...
Take spark plug out ,put sparkplug wire on plug and let it lay against block. Watch to see if plug fires. If not change coil. Hope this helps.
May 18, 2009 | Garden
Toro Lawn Mower With Toro Power Tools Logo
87 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
