SOURCE: Oven Problem
Check power going to the electronic module in back of the display. If power there you have a blown module. If no power check for a blown thermal fuze.
SOURCE: Kenmore Gas Oven F10
check the temperature sensor. TURN POWER OFF!If you open the panel where the controls are located you will see a connector that has about 10 wires on it. 2 of these wires will be violet. Pull off the connector and check the resistance between the 2 violet wires. It should be around 1000 Ohms.
If not, it is bad. part# for the Kenmore Model 790 is 316217001 - cost is about $25.00
SOURCE: how to calibrate double wall frigidaire ovens.
plaese post model number to assist you further. directions for calibration should be in user manual..
SOURCE: New replacement thermostat needs calibrating on my Kenmore oven
There is no real way to calibrate the thermostat. Most ovens have the same problem. By lowering the setting slightly will help get a closer temperature. Sometimes similar thermostats are substituted and may not be exactly the same as the original that came with your oven. Hope my trying to answer your question was helpful, Thanks, Sea breeze
SOURCE: My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
