Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
My Maytag Quietseries 300 has suddenly stopped draining H2O
The dishwasher has been working fine (1-11/2 yrs) until a few days ago, now there is water that is remaining in the bottom of the unit and I guess isn't being pumped out. Any suggestions to how to figure out what the problem could be..like is it a fuse, a plugged hose, or what. Any help will be much appreciated.
I had the exact same problem and did the exact same solution as tombax. It was working fine for 6 years until I came home tonight and my wife had a dish water lying in the bottom. I pulled the pump off (see tombax's post). If you then remove the white L pipe (3 torx screws), you will be able to see the impellar for the pump. There is a thin black plate directly under the impellar. Gently work it up and the impellar will come out of the housing (it's magnetic). Clean out around the magnet and inside the housing. I found build up there also. I put it back together and it works perfect.
Posted on Aug 05, 2009
My Maytag Quietseries has the same problem after less than 2 years. Mine is caused by using granular dishwasher detergent, which is the most common type of detergent. I took apart the entire pump inlet section (need a torx scew driver and a small socket for the impeller) and found the white abrasive material from the detergent (Cascade in my case) was packing in and pluging up all areas of the inlet. After I cleaned it all out & reassembled, dishwasher was back to 100%. Also noticed the normal cycle worked much better as well.
Posted on Jul 30, 2009
How should I clean the Maytag Quiet Series 300 with vinegar?
just fill it with water no soap and drop in vinegar right in the water and let it run its cycle
Jan 27, 2015 | matag Maytag QuietSeries 300 Dishwasher...
Wont drain
most have a valve that is operated by a solenoid valve, possible that wires have come off, or valve is stuck shut
Jan 22, 2015 | Maytag QuietSeries 300 Dishwasher...
Control Panel Problem on a Maytag DW MDBTT79AWW
I had this same problem, ordered the replacement control panel from whirlpool. The new panel worked for two weeks, then stopped working again. OUCH!
The replacement part costs $264.34 and has no warranty if you do it yourself.
I think I am now going shopping for something other than a Whirlpool or Maytag machine. They have terrible customer service.
Feb 12, 2010 | Maytag Dishwashers
Quietseries 300 : Fills OK, timer functions OK, no water movement
Check the Lid switch. Most top load machines will not spin unless the lid is down and this is determined by the lid switch.
Jan 07, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
Maytag quietseries 300 dishwasher not cleaning properly
UNGLOGGED THE BOTTOM/TOP . CLEAN IT AND SHOULD BE OKAYARMS SPRAYER, THEN IF IS GOOD AN NOT ENOUGH WATER CHECK WATER VALE SCREEN
Aug 19, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Maytag Jetclean problem
Hi!!! 10 years is alot for a dishwasher..You could have a plugged drain pump.Check your drain pump.All make sure that the water inside your dish water is hot inside it should read over 100 plus..Good luck..
Jan 03, 2009 | Maytag MDB9600A Jetclean II Built-in...
Maytag 300 Quiet Series Dishwasher
Unit will not turn on..had this unit for 6 months..worked fine..all of a sudden wont turn on now..checked power and connections..all were good..im stumped..just wont turn on.
Feb 15, 2008 | Dishwashers
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
263 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
